Old August 25, 2011, 12:57 PM
chrisk's Avatar
Folding Captain
Default Water disappearing from loop?
Folks banging my head over this one.
My folding rig (see the "Foldy" specs in my system info) is a pretty simple setup. After I put the loop together about a year and a bit ago, I noticed last winter that the water levels in my EK tube 150 res had gone down to the point where air was being sucked into the pump (could hear the bubbles in the loop). So I checked for leaks, and refilled the res. Checked again and found no sign of a leak (ie wetness, or residue from the coolant). I use distilled with dazmode additive.
A month or so later, I tore down the loop and cleaned everything up. Assembled the loop, remembering that I somehow lost coolant prior. I was thinking evaporation, so I was careful to make sure everything was sealed tight and nothing was open. Also looked around the case to make sure there were no coolant stains etc (the dazmode additive left a white residue on another rig that I had that did in fact leak...no sign of it here).
Got home from summer vacation last week, and again heard bubbles flowing through the loop. Again, the res was almost empty. I cannot find a leak anywhere, and as far as I can tell no open gaps where water could evaporate, as far as I can tell of course.
What is going on here? Normal over 6-8 months? Only thing I can think is this is just an instance where I did not bleed air out of the loop good enough, and it eventually makes its way into the res?
Fold for team #54196
Old August 25, 2011, 12:58 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Normal. I have to refill mine as often.
Old August 25, 2011, 01:02 PM
Keywork's Avatar
As soon as I read the thread title I immediately thought evaporation but after reading, i'm not so sure. My loop has been running 24/7 since Christmas and i've MAYBE lost a millimeter or two in my res. Something is fishy here.... How warm do you keep your computer room out of curiosity? And is your res top screwed on tightly?
Old August 25, 2011, 01:06 PM
chrisk's Avatar
Folding Captain
Room is very warm (basement with small window, two computers folding 24/7, for weeks at a time...good ol UPSes). The main computer I have, with a similar setup, does not do this (or maybe just a tiny bit, if at all).
edit: evaporation through tubing? I forget the brand, but its the 1/2ID stuff daz sells.
Old August 25, 2011, 01:29 PM
Just get a bigger res or put in an extra res. It's probably evaporation.
Old August 25, 2011, 01:32 PM
Sagath's Avatar
This is normal. Water can and will leave your loop, regardless of how well you make it air tight. Its not a matter of evaporation (though I doubt how well any of us seal our Res that they are actually 'air tight'), and I'm not 100% that the tubing is non-porous either. The water will break down eventually and leave the loop.
I work on this a lot with Dialysis. Obviously the mechanisms are different, but we learned about the issue in school with closed loop systems. I'd guess (napkin math pulled up from the back of my brain from school) that a closed loop water system would lose about 5% a month, but it could be higher, depending.
Originally Posted by Lpfan4ever View Post
AKG shot the hamsters, and then Perineum drove his Mustang with summer tires into the server.
Old August 25, 2011, 01:33 PM
SugarJ's Avatar
Got any elbows in your loop? I had an extremely slow leak in a 45 deg elbow once, so slow that it would evaporate before dripping. The only reason I figured it out was the accumulation of dye on the outside of the elbow.
Old August 25, 2011, 01:37 PM
chrisk's Avatar
Folding Captain
I thought about a very slow leak. I had a slow leak in my main rig that left a bit of white residue from the dazmode protector, and I cannot find any of the residue using the same stuff in the loop with missing coolant.
I am thinking it could be evaporation in the tubing. Maybe I'll tear this down again for a cleaning and take another look around.
Old August 25, 2011, 01:38 PM
if there are no signs of slow leakeage on the bottom,look up top there has to be an exist for the vapors.
probably nothing much since you should notice if it were more.
Old August 25, 2011, 01:43 PM
3.0charlie's Avatar
Normal.
Evaporation.
Sweating through tubing.
Micro-leaks.
Fill, repeat.
Water Loop enaberif Water Cooling 8 July 17, 2009 09:35 PM
[FS] P5Q PRO/HD4870 512MB/water cooling loop b1lk1 Buy/Sell & Trade 6 March 28, 2009 05:53 PM
Disappearing OS? dadzilla Troubleshooting 7 March 16, 2009 09:30 PM
Best way to add water to a loop ebdoradz Water Cooling 9 January 18, 2009 10:48 PM
Ram Water Cooling loop Shredder Water Cooling 5 January 24, 2008 08:55 PM
