Old February 13, 2008, 02:38 PM
Default placement of barbs
Is it better to have the rad barbs on the top or the bottom for bleeding and performance. If the barbs are on top would you get more air trapped in rad or would it matter
intel 960@4560 mhz giga ex58 ud5p
g-skill 12gig 1600 @1736 8-8-8-20 1t 1.6v
swiftech gtz waterblock
dual serial 655 pump
240 feser/360feser rads
diamond 4870x2 ek fullcover block 38c idle
2.29 tb hds
dual pioneer dvd burners
25.5 asus lcd
mountain mod case
12x120 mm fans
corsair 1000w
Old February 13, 2008, 02:43 PM
Doesn't matter.
Old February 13, 2008, 02:53 PM
3.0charlie's Avatar
Top or bottom barbs - the air bubbles will still follow the same path.
Hydro-Quebec is salivating...
Help with propper barbs and rad? Jack Rabbit Water Cooling 6 January 3, 2008 12:20 PM
