Old August 20, 2011, 11:53 AM
ragenrok's Avatar
Default MCW60-R on a 6950, best way to cool rest of card?
I have a MCW60-R gpu block that works great and I would love to use it again on my HD 6950 but not sure whT i can use to cool the rest of the card. Up till now Ive always used a uni-sink for my cards along with it (used it on a 8800gtx and a gtx260).
Anyone have a suggetion?
Old August 20, 2011, 12:02 PM
Swiftech still makes uni-sinks for newer gen cards.
If you have good airflow in your case, you could save some cash and just get some mosfet/vram heatsinks.
Old August 20, 2011, 08:15 PM
KaptCrunch's Avatar
old fish tank filled with veg oil ....J/K
ilya is on the right track
Old August 20, 2011, 11:46 PM
I see that EKWB has a "full-cover" waterblock that is visually compatible with reference designed AMD HD6950 videocards EK-FC6970 - Radeon HD 6xx0 Series - Full Cover for AMD Radeon - VGA Blocks - Blocks
goes for about $113.70 (U.S.) or $112.55 (CAD)
Here's a quick link for compatibility CoolingConfigurator.com
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
Old August 21, 2011, 05:49 AM
chubaka's Avatar
if you hav the reference 6950.. i think you can leave the stock heatsink with the fan assembly. Im basing this on nvidia's 470,570,580 reference design...(so im not really sure)
Old August 21, 2011, 07:45 AM
KaptCrunch's Avatar
question is it worth the hassle getting a inferior product due to eddy's eroding product
Old August 21, 2011, 12:26 PM
This was just the first place I checked; I know that Daz carries a few others (that are not from EKWB)
K- Full Cover GPU Block for Radeon HD6970/6950 - VID-AR697 K- Full Cover GPU Block for Radeon HD6970/6950 - VID-AR697 [VID-AR697] - $149.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
Watercool HEATKILLER® GPU-X³ 69X0 Watercool HEATKILLER® GPU-X³ 69X0 [15009] - $127.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
Aquacomputer aquagrATIx for HD 6970 Type 2 (Cayman XT) [23521] - $119.99 : DazMode, The Best Canadian PC Watercooling and Modding Store!
Homer J. Simpson
[FS] XFX 6950 2GB stuck at 500mhz, selling it cheaper, sold mckchun Buy/Sell & Trade 11 December 21, 2011 06:02 AM
Budget Case for XFX 6950 2gb card El-Producto Cases 9 August 22, 2011 10:46 AM
Sapphire Launches Radeon HD 6950 TOXIC Edition, Fastest HD 6950 Yet Sam_Reynolds Press Releases & Tech News 2 August 5, 2011 02:25 PM
Q9550 to stock cool or custom cool? lKashl CPU's and Motherboards 11 June 11, 2009 04:33 AM
Where is the rest of my HDD CasheKicker O/S's, Drivers & General Software 13 March 13, 2008 03:37 AM
