Old August 19, 2011, 06:06 PM
NI3 NI3 is offline
Default Connecting GPU blocks with different size tubing?
Another somewhat different question for the watercooling section.
Is there anything terrible with connecting two XSPC Rasa GPUs together using different size tubing?
Everything else will be the same.
I will be connecting with the same now, but for future knowledge, is it terrible?
Old August 19, 2011, 07:31 PM
ZZLEE's Avatar
Smaller diamter requiers more pressure to get same flow. Pi R sqared is area of a circle so smaller area less volume in the tube. Smaller the tube more friction loss to flow in the tube. the most constrictive part of your set up governs the flow of the entire set up.
do a test wile setting up. 1 gallon of distilled water with small fitting and big fittings test the time it takes to fill a 1 gallon container that will give you gallons per hour of your set up.
Table top test. ?
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Tubing size Chipset Question elwoodz Water Cooling 5 December 14, 2009 04:04 PM
Tubing size vs performance Jmark Water Cooling 12 October 19, 2009 03:27 PM
Tubing, tubing... what to choose? Dazmode Water Cooling 16 June 23, 2009 02:32 PM
connecting 2 networks Phobia Networking 4 March 3, 2009 09:23 PM
Connecting PC to a HDTV. werty316 Display Units 3 April 7, 2008 05:22 PM
