-   -   Watercooled Sniper by a simpleton (http://www.hardwarecanucks.com/forum/water-cooling/45714-watercooled-sniper-simpleton.html)
Simpleton August 17, 2011 04:42 PM
2 Attachment(s)
Hi,my take on the Sniper.
Simpleton August 17, 2011 05:10 PM
2 Attachment(s)
Mounted the big fan on the top of the case it just fits under the cover with a little trimming of the inside of the cover but in now way disfigures the outside appearance,you lose use of the back handle though of course, just stick you'r fingers in the I\O recess which is deep and makes a great option for carrying it.
Also I moved the holes for the rad so it would be farther from the motherboard for clearance issues.
If you follow this tips you should have no trouble watercooling this case.
Simpleton August 17, 2011 05:48 PM
1 Attachment(s)
That fan on top is really too bright for my taste.Gonna switch out all the case fan led's for ultraviolet.
Simpleton August 17, 2011 05:52 PM
1 Attachment(s)
There's my simple loop with uv reactive coolant,damn those blue led's wash out everything!
Simpleton August 17, 2011 05:56 PM
1 Attachment(s)
reservoir and pump! Simple!
Simpleton August 17, 2011 06:02 PM
1 Attachment(s)
Front shot,again too bright.
Simpleton August 17, 2011 06:09 PM
1 Attachment(s)
This is after I installed uv led's in all the fans, they are like a deep fuzzy purple light not too bright!This shot is in the dark.
Eldonko August 17, 2011 06:23 PM
Looks good :)
Keywork August 17, 2011 06:59 PM
Are you using an EK pump out of curiosity?
martin_metal_88 August 17, 2011 07:45 PM
Is that fan on the second pic yellow because of cig smoke lol XD
Very nice looking, could we have a pic of the un-zoomed interior plz?
