-   -   What Watercool kiy to buy (http://www.hardwarecanucks.com/forum/water-cooling/4524-what-watercool-kiy-buy.html)
jasonmoreau February 9, 2008 09:58 AM
I'm looking to go water cool on my e6750 and 8800gts 512mb which of these two kids should i go for. I will obviously O/C my system higher then it is right now.
e6750 @ 3GHz = 61C full load for 24hours stock cooling
8800GTS 512mb @ core 780 mem 1000 78C running Crysis for a little over 1hour 55% fan speed
PC CYBER CANADA - For All Your Computer Needs BETA
or
http://www.ncix.com/products/index.p...nufacture=NCIX
and add
Reservoir and GPU block
Babrbarossa February 9, 2008 11:10 AM
The NCIX kit is a better value, but I would go for a 2X120mm radiator- either a HW labs black ice extreme or a thermochill pa120.2
this is an awesome kit that comes with a pa120.2, but it costs 299
3.0charlie February 9, 2008 06:43 PM
Definitely go for the kit Babr suggested, and simply add a GPU block. It is a very, very good kit.
jasonmoreau February 9, 2008 10:16 PM
or
and add
i dont really want to spend over 300 on a kit right now
3.0charlie February 10, 2008 06:50 AM
Then forget about cooling the GPU.
Babrbarossa February 10, 2008 07:13 AM
yeah- I'd say the same. Either just use a single rad for your CPU, or wait until you can afford a double rad along with decent blocks and pump rather than having to upgrade components when you decide you want good performance for cooling both the GPU and CPU.
flybye February 11, 2008 11:25 AM
be smart
jasonmoreau i wouldn't buy a kit there is always something just not up to par in most kits. Build ur own it would not cost very much more and you get everything you want . Do the reviews and don't buy cheap tubing, tygon is the best and one of the best pumps is swiftech 655 come to think of it swiftech makes just about the best in all water cooling products just be careful certain blocks are made for single and dual core chips yes it does make a difference. Also go with the half inch setup. The 655 puts out 1200 liters per/hr and there are 2 versions one does not allow you to set the pump speed the other does. Again swiftech makes the best, oh stay away from the clear tops as they will break sooner or later, go with full copper blocks not good to mix aluminum and copper. Note to newbies always check many reviews don't just jump word of experience! good luck
