Old July 27, 2011, 11:00 PM
Default H50 Mod Help
Hey guys so im looking to perform this mod on my H50 .....its summer time im kinda bored and prone to tinkering.
Anyways this is the tread im referring to (Guide) H50 Replace Tubes and Res Mod. - Overclock.net - Overclocking.net
Anyways i wish the author was a bit more specific on the things he used. im gonna get the micro res off a forum member on this forum Watercooling setup (775, EK FC GT200-B)
but i wanna use compression fittings as they look much cleaner. My question is he uses 8mm ID 10MM OD tubing, the thing that is messing me up is the difference in imperial / metric measurement. compression fittings come in
1/4" = 6.35mm
3/8" = 9.525 mm
7/16 and 1/2 are both obviously too big.....
What kind of compression fitting did he use>? i cant find any in metric
and can i just buy this tubing at home depot?
Total WC noob ,,,,,,sorry
i7 920 D0 @ 4ghz
Corsair H50
Asus P6X58D-E
6 Gb Corsair 1333
2x 460 768mb
Element S
Old July 28, 2011, 05:01 PM
IITSChiefII's Avatar
Dont really understand the problem. from what i just read on the net the barbs on the h50 are 1/4id
so just buy 1/4id 3/8od Compressions and tubing.
if he used some weird larger id tubing it would be more prone to leaking and would need more clamps and since its thinner walled higher chance for kinking.
Old July 29, 2011, 10:41 AM
right right thanks ...it was a late night when i was looking at that ....probs why i was kinda confused
i7 920 D0 @ 4ghz
Corsair H50
Asus P6X58D-E
6 Gb Corsair 1333
2x 460 768mb
Element S
[FS] Corsair H50 mattlef Buy/Sell & Trade 1 January 8, 2010 05:18 PM
[WTB] Corsair H50 sinticfury Buy/Sell & Trade 6 December 20, 2009 12:29 AM
The Dark Mod - Thief Inspired Doom 3 Mod Thund3rball Gaming 2 October 20, 2009 07:11 AM
UV Mod = Epic mod, makes ur computer look 100x Better arekieh Case Mods, Worklog & Gallery 12 March 29, 2009 12:13 PM
Antec Plusview 1000 Mod, my first mod need help... thatguy Cases 6 July 14, 2008 08:48 PM
