Old July 21, 2011, 05:39 AM
JD JD is offline
Originally Posted by jtf2 View Post
rrtech facilitates the plating for hk blocks sold at sidewinders,and trust me when i say-as i own a nickel-chrome block plated at the same place-those blocks are plated inside and out,and honestly i would like to see an example of a block plated-on the outside only
I thought Sidewinder's website had pictures and it wasn't plated internally. Perhaps it was P-PCs. Honestly, I can't recall as it was so long ago when I went to buy mine.
Old July 21, 2011, 06:19 AM
Xilikon's Avatar
The HK sold by Sidewinder was plated by RRTech and it's inside out. I also own the first batch HK3.0 (currently for sale, wink wink).
I never saw a block which was plated only externally but it's also possible there are some who only have the top plated while still retaining the naked copper bottom.
Xilikon - Team 33
Proud to be [H]ard !
Old July 21, 2011, 07:26 AM
I can confirm that the HK blocks (my GPU GTX580 block) has a VERY tight fit with the threads using BP compression/rotaries.
Old July 21, 2011, 10:28 AM
The one I got has copper bottom and is not internally coated. But I dont usually look at the underside or internals when its installed, so I think I'll be ok.
HeatKiller 3.0 Mounting? AmuseMe Water Cooling 12 October 11, 2010 09:21 PM
HeatKiller 3.0 @ 87C WTF?! anabioz Water Cooling 71 April 26, 2010 08:44 PM
Heatkiller 3.0 Apollo4g Water Cooling 88 January 30, 2010 04:21 AM
[FS] Mountain Mods H2GO, 120.1 Radiators, Bitspower fittings, HeatKiller Blocks Liu Kang Buy/Sell & Trade 17 January 27, 2010 07:49 AM
Heatkiller + Backplate JD Water Cooling 5 January 3, 2010 08:12 PM
