-   -   Case for Triple Radiator (http://www.hardwarecanucks.com/forum/water-cooling/44921-case-triple-radiator.html)
Cs342 July 15, 2011 06:29 AM
Hello,
I will be buying an XSPC RS360 water cooling kit very soon and i want to know what cases there are that will be able to fit this radiator with no problems at all. Preferrablyaround $150 USD if possible. Thanks!
coleo July 15, 2011 08:51 AM
i do believe the SS RV-02E has room enough to mount a triple on the bottom side under the 3 180 mm fans. plumbing grommets are already built into the case for WC as well
chrisk July 15, 2011 08:57 AM
I have used the Coolermaster HAF 932 and Corsair 800D with internal triple rads with 6 fans attached. Also the ATCS 840.
You might find the HAF cases more within your budget.
Cs342 July 15, 2011 09:18 AM
What would be the cheapest case for a triple 120mm rad?
SugarJ July 15, 2011 09:30 AM
Cheap and watercooling are at opposite ends of the spectrum. If you are looking for an internal mount, it pretty much means a full tower.
If your budget is that tight, almost any case will do if you go to an external mount with a rad box.
Soultribunal July 15, 2011 10:35 AM
Very true,
Cheapest I would go with WC internal is the HAF932.
ST
brewer265@ July 15, 2011 10:52 AM
Coolermaster ATCS840 $160 at NCIX right now
NCIX.com - Buy Coolermaster ATCS840 ATX Tower Case Black 6X5.25 6X3.5INT 1X3.5EXT Front USB Firewire eSATA Audio - COOLERMASTER - RC-840-KKN1-GP - in Canada
KylSp July 15, 2011 03:11 PM
Can't beat the big black monolith (700/800D) :)
Cs342 July 15, 2011 05:41 PM
I was thinking of the Thermaltake Chaser MK-1 for an internal triple rad, would that fit?
Newegg.com - Thermaltake Chaser MK-I (VN300M1W2N) Black SECC ATX Full Tower Computer Case
sswilson July 15, 2011 05:55 PM
Have you seen any references or build logs that show a radiator going into one? It claims to be water cooling ready, but that could just be refering to tubing holes on the back panel......
It's pretty hard to tell from the information provided on that page. Unless you're a seasoned WC/Modding tech, I'd strongly suggest sticking with something that's been tried and true....
