<~----> Case for Triple Radiator - Page 3 - Hardware Canucks
  #21 (permalink)
Old July 16, 2011, 02:21 AM
If the RS360 will fit in the HAF 932 Advanced without modding then I'll definitely get that.
  #22 (permalink)
Old July 16, 2011, 12:48 PM
Keywork's Avatar
Man, grab that ATCS840 for $160. Solid price for a hell of a case! I've got a triple rad sitting comfortably in the top of mine...
  #23 (permalink)
Old July 16, 2011, 02:40 PM
SugarJ's Avatar
Here's chrisk's build log with his triple in the top of his HAF 932. Going under water for the first time, part 2: moving to a new home
  #24 (permalink)
Old July 16, 2011, 03:20 PM
chrisk's Avatar
Folding Captain
Yep the triple rad will fit right into the top of the case no mods required, even for 6 fans in push-pull on the HAF 932 and the ATCS 840. Actually, the ATCS 840 has plastic adapters for that purpose specifically that come with the case.
I have done two builds with the HAF 932. Here is one build with the bay res and using the fill port hole on the 932:
And here is another similar rig I built (still using), that uses no fill port and has the tube style res mounted inside:
Water-cooled folding rig
If you look at both of those posts and look through the threads, you will see that I used triple rads with 6 fans no problems.
The ATCS 840 and also the 800D has a little bit more room, but nothing spectacular.
For $160 the ATCS is a great deal, but if USB 3.0 is important then you should get the 932 advanced linked earlier.
Fold for team #54196
  #25 (permalink)
Old July 16, 2011, 06:25 PM
So it looks like I won't have to buy the HAF-X then...
  #26 (permalink)
Old August 12, 2011, 09:13 AM
Cptn Vortex's Avatar
Its quite easy to fit even 2 x Tripple Rads into the ATSC.... Like my system :
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Tags
case , triple radiator , water cooling
[FS] triple 120mm watercooling radiator, 1.25" thick (Black Ice Extreme ll) elninio Buy/Sell & Trade 0 November 28, 2010 02:36 PM
Mount and bleed a top mounted radiator in HAF X case kkkwj Water Cooling 11 November 7, 2010 06:27 PM
WTB: triple radiator ( 120 x 360) elninio Buy/Sell & Trade 0 January 22, 2008 10:52 AM
Triple SLI is here.... Prof. Dr. Silver Video Cards 16 December 19, 2007 04:55 PM
