Originally Posted by Pax So a few years ago, I bought a Swiftech Apex Ulitma Plus kit to start my foray into WCing. Since then I've had a child, and my wife is due with our second this weekend. In other words, I won't have much time to maintain my loop anymore.
I think the kit came with the following:
Swiftech Apogee GTZ Water Block
Swiftech MCW60 VGA Water Block
Swiftech MCRES-Micro Revision 2
Swiftech MCP655-B Water Pump
Swiftech MCR220 Dual 120mm Radiator
Swiftech MCB120 Radbox Revision 2
And a bunch of plastic barbs. I bought a bunch of TFC barbs and some 90/45 degree rotary barbs from Daz instead of the plastic ones that came with the kit.
I guess my big question is, is there much of a market for this kind of stuff on BST? If so, how much could/should I sell it all for? |
You're not going to get much for a watercooling kit that is a few years old, and especially Swiftech stuff IMO. I would hope for your sake you have a few hours to yourself once every 6-12 months :)
For example:
Swiftech Apogee GTZ Water Block $15?
Swiftech MCW60 VGA Water Block $15
Swiftech MCRES-Micro Revision 2 $10
Swiftech MCP655-B Water Pump $20
Swiftech MCR220 Dual 120mm Radiator $20
Swiftech MCB120 Radbox Revision 2 $5
Is it worth it to sell for $60-80 plus whatever extra little fittings you have? If you're getting rid of it for money, it's better to just keep it as you're losing out huge on your investment versus keeping some of the stuff. If you're getting rid of it because you'll never use it and hope someone else can enjoy it - I'm sure someone would pick up the whole thing as a bundle for $60-$80. Compare it to a brand new RASA kit etc. for example and you'll see a very old kit like this isn't worth that much anymore unfortunately.
