  #31 (permalink)
Old July 12, 2011, 08:19 AM
Slaughter's Avatar
Originally Posted by bvsbutthd101 View Post
Both of those links are for Pump TOPS. Not full pumps.
One is for the D5 and the other the DDC.
  #32 (permalink)
Old July 12, 2011, 10:07 AM
bvsbutthd101's Avatar
the koolance pump is a full pump, but that EK top im looking at won't fit it?
  #33 (permalink)
Old July 12, 2011, 10:16 AM
Slaughter's Avatar
My apologies. You have 3 links there. 1 Koolance Pump and 2x EK Tops. One for a D5 and one for a DDC.
The D5 top fits the Koolance Pump.
And instead of buying the whole EK Pump
This link is to the Pump TOP that will fit the koolance pump. It is not a full pump.
  #34 (permalink)
Old July 12, 2011, 10:21 AM
yeah i just realized that the separate EK top piece that i looked at want fit the koolance pump
  #35 (permalink)
Old July 12, 2011, 10:33 AM
Slaughter's Avatar
The DDC is the MCP350/355 pump.
  #36 (permalink)
Old July 12, 2011, 11:04 AM
ill just stick with buying the two separate pumps and taking the top off the EK pump and putting it on the koolance pump.
  #37 (permalink)
Old July 12, 2011, 11:15 AM
Slaughter's Avatar
Can you please link me to the EK pump you are talking about? I think you might be confused... Or I'm really confused...
  #38 (permalink)
Old July 12, 2011, 11:26 AM
bvs.... you need a top, and a pump. Most pumps come with a top already installed.
It's like 2+2=4, even a 5 year old can do it :) Just read the descriptions on the products.... it really is pretty simple bud.
  #39 (permalink)
Old July 12, 2011, 12:03 PM
Koolance D5 vario pump with tach wire
Koolance PMP-450 High-flow Pump Products Model: PMP-450 [PMP-450] : Performance-PCs.com, ... sleeve it and they will come
EK D5 Xtop Rev 2
EK-D5 X-TOP Version 2 Products Model: EK-D5 X-TOP-V2 [EK-D5 X-TOP-V2] : Performance-PCs.com, ... sleeve it and they will come
Codeman, this is what you sent me, I'm getting these two
  #40 (permalink)
Old July 12, 2011, 12:15 PM
chrisk's Avatar
Folding Captain
No.
First, you buy this PUMP:
Swiftech MCP655™ 12 VDC Pump [MCP655-B] : Performance-PCs.com, ... sleeve it and they will come
Then, you buy this TOP:
Then, you put those two together, as per the instructions that come with the top.
I have included a handy picture of the TOP I have mentioned in the SECOND link above.
Note that in my picture, the stuff I have marked with the colour RED is NOT included with the TOP...you only get the BLACK object you see, that is not clearly marked in RED.
Fold for team #54196
Missing Anna Lpfan4ever O/S's, Drivers & General Software 5 March 20, 2010 12:23 AM
What Am I Missing? El_Fiendo Off Topic 8 October 14, 2009 06:39 PM
Cores missing! BT! CPU's and Motherboards 4 February 10, 2009 05:26 PM
'View All' not there? or am I missing it. biff Suggestions & Feedback 3 September 22, 2008 12:38 PM
missing wire ? Jim Troubleshooting 5 May 31, 2007 05:02 PM
