Old July 4, 2011, 05:50 PM
Default Just a heads up on water cooling MIS 570gtx
If you are thinking of using the EK-580 block to cool your MSI 570 GTX card it will no longer fit. MSI has changed the chip lay out of the newer cards. They are using the same SKU on both cards even though itís a different chip lay out. The (newer) card is a little shorter and has a MSI logo on the exhaust. I found out the hard way
New to Water cooling! Slaughter Water Cooling 53 February 17, 2011 09:26 PM
New To Water Cooling mjbdc07 Water Cooling 10 August 31, 2010 05:25 AM
IW heads fired by activison, heads file suit in response BrianHanna Gaming 0 March 4, 2010 02:37 PM
new to water cooling jay51 Water Cooling 13 June 22, 2008 03:10 PM
