Old July 3, 2011, 11:02 AM
Default From stock Intel cooler to Corsair H70 on p8p67pro with Intel 2500K
15'C cooler
OC'd to 4.6 GHz stable.
That's a win!
Old July 3, 2011, 11:28 AM
Kipper's Avatar
Hardware Canucks Reviewer
What are the temps under full load?
Old July 3, 2011, 12:53 PM
Arinoth's Avatar
Good to hear, though that should be expected to when switching from Intel's crappy stock to some real after market heat sinks. Kipper is correct, temperatures under load is what you really want to see the difference then idle.
Old July 3, 2011, 02:16 PM
Wow, it looks I really have to replace my Intel's stock cooler to the corsair H70. Btw, I don't know if I should buy the H70 or the expensive one, the H100.
Old July 3, 2011, 02:22 PM
lowfat's Avatar
If you have room for the H100's radiator then it would definitely be the best choice.
Old July 3, 2011, 02:26 PM
Oh forgot that it has that "XL radiator" :/
But I can mount it out of the case, right?
My case has that rubber holes in the back, besides the case is small :P
Old July 3, 2011, 02:51 PM
Thats 15'C cool idle (60C -> 45C)
Under heavy load (Handbrake) I haven't seen it go above 61 yet.
Old July 3, 2011, 07:13 PM
I'd take the H60 over the H70 as it works just as well and doesn't take up near as much room and uses corsairs new pump
Old July 3, 2011, 10:53 PM
supaflyx3's Avatar
15 degrees cooler on a 4.6GHZ OC... that doesn't seem right.. should be alot less.
Old July 4, 2011, 05:03 AM
Arinoth's Avatar
Something does sound off, shouldn't be idling at 60C with the stock cooler, or around 40C with his after market. When i had a CM 212+ installed i'd idle in the 30s and that has less coolant power then his LQ.
Corsair Hydro H70 CPU Cooler ? Rush Water Cooling 9 March 24, 2011 06:34 PM
Upgrade from ZALMAN CNPS10X Performa cooler to Corsair Hydro H70 cooler completed dosmond Water Cooling 3 September 3, 2010 02:27 PM
Intel Core i7 980XE Stock Cooler BigDogg CPU's and Motherboards 3 March 10, 2010 12:33 PM
The End of an Era - R.I.P. Intel Stock Cooler Soultribunal Press Releases & Tech News 24 October 16, 2009 09:04 PM
