Old June 22, 2011, 06:53 AM
Slaughter's Avatar
Looks good but I would definitely try to minimize the amount of tubing used. :P
Old June 22, 2011, 04:14 PM
Amarthfea's Avatar
i love the colour of that tubing!
dang that case makes everyting look small.. nice!
~Elysium, I behold your beauty...
Old June 26, 2011, 03:31 PM
elton5354's Avatar
+1 on others saying the colour of the tubing is really nice! love it!
Old July 4, 2011, 12:59 PM
The colour of the tubing is pretty good. I am going to be doing watercooling set up for a customer soon and he doesn't know what he wants at all so I am definitely going to suggest this.
Old July 4, 2011, 05:30 PM
Nice work on the water cooling set up.
Old July 5, 2011, 09:01 AM
You might want to tell the customer to shortening up the tubes though ...I've generously went for longer tubes so when I re-fill/bleeding the loop, so I don't have to remove everything out. And don't have to shake/roll/lean/sideway the case to get all the bubbles out. Damn thing is heavy and don't want my sweaty fingers slipped. However, aesthetics-sake, it's a mess.
1st - ASUS P8P67 Deluxe, i7-2600K o/c 4.6Ghz, Corsair Vengeance DDR3-1600 16Gig, 2x HIS Radeon 6970 CF, Custom WC from Dazmode, Corsair AX1200, Corsair P3-128 SSD, Coolermaster HAF-X
2nd - ASUS P5B Deluxe/WiFi-AP, Q6600 o/c 3.6Ghz, Corsair Dominator 6Gig, Sapphire 5870V2, Swiftech H20-220 Ultima XT, Corsair AX850, Antec 900
Old July 5, 2011, 10:52 AM
Haha, hadn't realized you'd replied :P
And yeah, though I did notice the long tubing I was also kind wondering if that served a purpose :P As for the shake/roll/lean, would you have to do all that when you're just refilling? I thought refilling was concerned with just adding more liquid to the res?
And aesthetically it isn't too bad :P it's a big case so it kind of fills it out :P
Old July 5, 2011, 01:23 PM
All that shake/roll/lean meant to take out all the little bubbles in the loop. You have the most air-bubbles when you first filling the tubes with liquid...stop and start the pump, several time is the key. Sorry for the confusion ...you're right, refilling is to top the res. NO rolling and shaking needed.
Well that's why you need a full tower...to fill it up...hehe
First PIC of the GTX 480 MarkOne Rumor Mill 6 March 4, 2010 09:51 AM
Now this is a beautiful sight *PIC* lowfat Overclocking, Tweaking and Benchmarking 12 October 20, 2009 07:21 PM
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 05:17 PM
Can you see this PIC? Dr_BenD_over Off Topic 5 November 4, 2008 07:13 PM
R680 pic donimo Video Cards 13 January 13, 2008 04:45 PM
