Yeah that's true. I don't actually have the SE version of the Maximus Formula, just the standard, so I do need to replace the heatsinks.
I guess I'm using those pics more for a guide and inspiration, but not necessarily to copy outright.
That's why I posted this here. I want to get it right the first time and I'm not in a hurry. I'd rather not start WC then add more later (yeah right, whoever heard of that around here?
I'd rather get a decent design concept and then work towards it little by little.
I'll have the money, just not all at once.
The Maximus Formula NB is notoriously finicky and apparently any temps over 47 degrees cause instability. Mine can get up to the 45 degree range right now, so I think it's worth putting in the loop. Maybe after the GPU.
As for the mosfets, I could probably do those with the HR-09 and the SB with the HR-05
