  #31 (permalink)
Old February 5, 2008, 04:49 PM
silverchair's Avatar
Question, in my cm-690, instead of putting 120.2 on top ( which is you guys said it really needs a drill and cutting), you think it might be good if i put 2x 120.1 rad, one on the top and one on the back of the case using a loop of tubing?
RC-690 case | 2x1gig corsair xms2 | Q6600 G0 Steppings | EVGA 8800GTS 320mb superclocked | Maximus formula X38 | Ultra Xfinity 600W | Zalman CNSP 9700LED
  #32 (permalink)
Old February 5, 2008, 05:37 PM
zlojack's Avatar
Good news! I just got a nice fat benefits cheque from the insurance company (I had forgotten about that claim!)
Time to buy some WC parts!
A question, how many feet of tubing should I buy?
  #33 (permalink)
Old February 5, 2008, 06:15 PM
Cptn Vortex's Avatar
buy 20ft. You will have a ton left over, and not worry about cutting too long or anything.
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
  #34 (permalink)
Old February 5, 2008, 07:27 PM
zlojack's Avatar
Alright, seems like a lot, but 20 it is...
I just ordered my Fuzion. Found it in stock at Jab-Tech
Anyway, I'm putting together an order of some stuff from NCIX.
I might split it into 3 or something so it's more manageable.
I think I'll go with the Microres.
I think I could put a fillport on top of my A900 and a drain on the floor of the case.
Having the rad in the front is pretty much a writeoff, so it goes on the outside after all.
  #35 (permalink)
Old February 5, 2008, 08:08 PM
lcdguy's Avatar
awesome. Now that your project is well under way you should start a work log so we can all drool of the watercooling.
  #36 (permalink)
Old February 5, 2008, 08:44 PM
3.0charlie's Avatar
Originally Posted by zlojack View Post
I was looking at the Micro-res. It would fit my case better, because where I was thinking about putting the drive bay res would conflict with my VGA card.
I'm still a bit confused about the res situation. Could I install the Micro-res with a fillport at the top of the case? Then run a tube from there to the pump. After the pump, a y-junction with a split for a drain and a line to the rad.... then the rest of the loop.
I think I need to get a photo of my case and do some photochopping....
EDIT: I just had a thought... I bet I could fit that radiator in the front part of my Ninehundred under the hard drives and use the front fans to pull the air out...
I might have to sacrifice an optical drive...hmmm... food for thought.
I guess I should start by ordering the rad and components and see if they'll fit. Time to take some measurements.
No need for a fillport when using the Micro-res.
Hydro-Quebec is salivating...
  #37 (permalink)
Old February 5, 2008, 10:15 PM
zlojack's Avatar
Excellent...
What about a drain? Leaving that out would probably make life easier...
I should also look at what I'm going to put in it... distilled water is supposedly the best. Although in keeping with my Red/Black theme, maybe some red coolant in there would look nice. (or some black!)
I think I'll have to keep my 8800GTX for the time being, since this project will use up the money I had benchmarked for a new GPU, but this is definitely more worth it...
  #38 (permalink)
Old February 6, 2008, 09:10 AM
zlojack's Avatar
Ok I ordered and started the worklog thread: http://www.hardwarecanucks.com/forum...html#post39117
Thanks for all the help guys!
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
Water cooling question Infiniti Water Cooling 11 December 26, 2007 12:11 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 10:22 PM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
AC Water Chiller project sizerkozak CPU's and Motherboards 27 March 13, 2007 06:26 AM
