Not exactly a science lesson, but just some basic info in simple terms. There are many factors which affect corrosion, including temperature, ph, salinity of fluid, etc etc...
However, if you are just talking about galvanic corrosion, it comes down the electrode potential difference between the dissimilar metals. The higher the potential difference, the faster the corrosion process will happen. IE the difference between Copper and Aluminum is 2.01v while the difference between Copper and Nickle is 0.59v. Copper and Brass would be slightly worse than Cu/Ni with a potential difference of 0.69v. In any case the "more anodic" material will be "eaten" while the "more cathodic" metal will be effectively protected from corrosion by the anode. In both scenarios the copper is the Cathode, so it will remain untouched while the AL or Ni will be corroded. So from looking at the pictures of other EK blocks and from looking at my own it is very apparent that this is simply an issue with he quality of the plating, rather than an issue of galvanic corrosion.
It is very common to use Aluminum, zinc, and magnesium as sacrificial anodes in water heaters, boats, and even some cars and trains. This is because they have a fairly low potential difference so they will be the anode in most galvanic reactions.
But wait! "Aluminum doesn't rust" many people will say. Forgive me if you already know this, but many people don't realize that Aluminum oxidizes almost immediately in air. The outer layer of the aluminum will "rust" into Aluminum oxide which then protects the underlying aluminum from the air. you can see this if you have a piece of aluminum that is somewhat dull and you scratch it, revealing the shiny aluminum underneath. That dull layer is the Aluminum oxide.
The other thing to consider in a WC loop is that if your fluid is completely non conductive, you will not have any corrosion (assuming there is no indirect contact via the case or wiring). It's pretty impossible to get completely pure water, but the less saline and the fewer minerals in your water the better.
Oh, and I'm not sure what your "green stuff" is without pics, but when copper oxidizes it does turn green. Just look at the statue of liberty or the roofs of the Canadian parliament buildings. However, you really shouldn't have any oxidation in your loop, unless you somehow have a lot of oxygen in your fluid.
