Old June 13, 2011, 07:48 PM
Jackquelegs's Avatar
You need to bleed the loop properly. It's obviously trapped air bubbles
Iapetos
Zephyranthes
Old June 13, 2011, 07:50 PM
this is going to sound stupid but by bleed you mean to drain the loop entirely and refill?
Old June 13, 2011, 07:52 PM
the water level in the reservoir is too low, the pump suck air at the same time
Old June 13, 2011, 10:34 PM
throttle your pump speed - your reservoir is way too small for the amount of flow you've got in that loop. You're going to have very very high flow rates in that tiny loop with one of those pumps on full blast.
Don't drain it, it's fine... run the pump on a slower speed for a while. After you run it for a while, loosen the cap on the top of the little reservoir to release some air pressure. That'll help.
Old June 14, 2011, 04:04 AM
Dan Dan is offline
The exact same thing happened to me when I built my loop, I tried everything, even tilting the computer in every angle possible with the pump going and nothing but after about 3 days it went away.
I guess there's an air pocket in the rad and it slowly bleeds itself.
Old June 14, 2011, 11:42 AM
how do I run the pump at a slower speed? it has a molex connector and then a two pin connector(but only one pin wired).
I think I'm just going to purchase a new res(tube style) and a new CPU block, not happy with the danger den one I have.
Old June 14, 2011, 08:39 PM
KaptCrunch's Avatar
any reason why case upside down
looks to me that you have the case upside down in that picture(the video card position tells it)
the rad on top or bottom of case ? best for bleeding system is have the MotherBoard flat down with cards facing up (ceiling side) and since the pump is loose turn it 90 an hold above case opening with towels below to catch any leaks/spills, fill rez to full then cycle pump on/off to get the air out
and fill rez when level drops after pump is off
Old June 14, 2011, 08:53 PM
haha no the case isn't upside down. it's a Lian-Li PC-A05NB, its just the way it's designed.
  #19 (permalink)
Old June 14, 2011, 09:09 PM
lol KaptCrunch, aren't you the guy running around with advice for everyone yet you've never seen a reverse ATX setup before? :P too funny!
Modus - to run the pump at a lower speed you'll have to hook it up to a good fan controller with a decent amount of wattage per channel to handle the power drain (you'll need a molex to 3pin fan connection plug). Either that, or you could try your hand at running the pump at 5 volts, by swapping out the pins in the molex plug accordingly; might not be your best bet though depending on the pump.
Which one do you have? A DDC 3.2, 3.25? I see the blue impeller...
  #20 (permalink)
Old June 14, 2011, 09:39 PM
it's a DDC 3.21. Where can I order WC parts in Canada? NCIX/Dazmode doesn't have much of a selection...
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
Need help with noise etc.. shadow of chaos Water Cooling 6 August 24, 2010 08:21 AM
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
120v outlet filter for noise, such a thing? (popping noise from speakers) On2wheels Troubleshooting 3 June 20, 2010 08:06 PM
Reservoir noise matsta31 Water Cooling 17 January 26, 2009 07:28 PM
