Old June 13, 2011, 12:27 PM
Default mixing rads
I have a question about mixing parts. I currently have swiftech everything. My cpu block, pump, and rad are all swiftech. I am thinking of maybe adding a single 140.1 to my loop to help with some of the heat. Dazmode has an EK coolstream XTC 140.1 in his store. Would adding that to my loop cause any issues mixing with the other manufacturers stuff?
Old June 13, 2011, 12:58 PM
lowfat's Avatar
That will be perfectly fine.
Old December 7, 2012, 11:56 PM
Different rads won't be a problem at all. The only possible problem i know when it comes to watercooling is mixing pumps(only applicable if you use two). Doubt you would ever need two pumps though.. Probably just a precaution if someone fears that one of their pumps may die at any moment..
Old December 8, 2012, 04:30 AM
KaptCrunch's Avatar
just set-up in cmos the cpu shut down @ 60c for most bios have this option
OP mixing rads provided their same metals inside rad
eg. alu and copper don't mix, makes fluid galvantic
Mixing RAM Brands/Specs okay? bkh2 RAM 9 January 5, 2011 05:19 PM
Mixing ram ToXic RAM 5 October 10, 2010 04:46 PM
Mixing RAM? technix RAM 7 May 4, 2010 06:52 PM
Mixing Manufactures in CF cwestwell Video Cards 10 March 3, 2009 03:05 PM
Mixing ram? Cadence RAM 14 December 9, 2008 02:40 PM
