Old March 1, 2007, 07:53 PM
Babrbarossa's Avatar
Have you ever considered a career in hand modelling?
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Old March 2, 2007, 02:28 PM
cdn_Madrach's Avatar
LOL. Na... too much arthritus lol.
Amd FX60 @2.9
Asus A8R32-MVP Deluxe
2 Gig Corsair XMS 4000PT
2 Ati X1900's @XTX Speeds
2 WD 160gg HD's in Raid 0
XFi Platinum
Tt 680 Watt PSU
SATA Plextor DVD
(Liquid Cooled) Swiftech Apex Ultra and 2 MCW 60's
Kandalf
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old March 2, 2007, 02:40 PM
Doesn't look like you'll be lapping that shiny gem have you checked the flatness?
Old March 2, 2007, 02:59 PM
Nope. Didn't think to check it for flatness . I was so impressed by the finish, I just threw it on lol.
Amd FX60 @2.9
XFi Platinum
Tt 680 Watt PSU
SATA Plextor DVD
Kandalf
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
Old March 2, 2007, 03:03 PM
I'm sure it's fine- read an article somewhere recently that said that once you go above bottom-of-the-line, there's not much to worry about anymore for flatness due to more precise maunfacturing
Old March 2, 2007, 04:04 PM
The swiftech blocks make my Tt blocks look cheap, and the swiftech installs so much easier. With socket 939 you don't even have to remove the motherboard. The gpu blocks also fit better.
Amd FX60 @2.9
XFi Platinum
Tt 680 Watt PSU
SATA Plextor DVD
Kandalf
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
Old March 4, 2007, 10:00 AM
In this pic you can see the diamond shaped pins inside the WB.
Amd FX60 @2.9
XFi Platinum
Tt 680 Watt PSU
SATA Plextor DVD
Kandalf
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
Old March 9, 2007, 04:59 PM
Done with WC parts. Just leak testing now then finish hookin up, pics and benches . Gonna try and post more pics tnite
Amd FX60 @2.9
XFi Platinum
Tt 680 Watt PSU
SATA Plextor DVD
Kandalf
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
  #19 (permalink)
Old March 10, 2007, 08:49 AM
looks good, those ati cards come with crap cooler's and high temps
  #20 (permalink)
Old March 10, 2007, 09:11 AM
b1lk1's Avatar
You couldn't be more wrong. THe stock ATI coolers are actually very good once you turn up the fan speed. They are also the only stock cooler to exhaust out the back. If you can take the noise, running them @ 100% will get you the same results as the best aftermarket air coolers. ATI just runs the fans at crazy low levels for sound issues.
If you haven't yet, get some heatsinks on the Vregs on those cards and rig up a fan to blow over that area of those cards. The Vregs will get quite toasty if you don't.
Post your WaterCooled PC pics here thread Apollo4g Case Mods, Worklog & Gallery 986 January 23, 2012 10:22 AM
Ati 1900XTX goes watercooled Vinnie Water Cooling 11 February 12, 2008 08:10 PM
Compact Watercooled Gaming Rig! (planning stages) Cptn Vortex Case Mods, Worklog & Gallery 9 January 11, 2008 09:57 PM
Watercooled X2900 XTX pic Babrbarossa Video Cards 12 September 8, 2007 07:40 PM
Awesome evga Factory watercooled 680i Babrbarossa CPU's and Motherboards 18 March 22, 2007 01:49 AM
