  #181 (permalink)
Old June 14, 2011, 01:17 PM
matari's Avatar
Since I am not willing to pull the trigger on the CPU 370, there are only two blocks that I like left: Kryos and HK 3.0. However, I hate the mounting system of the HK 3.0.
  #182 (permalink)
Old June 14, 2011, 01:32 PM
The ones who are gonna screwed the worst in this whole debacle will be the re-sellers. It will be hard to unload EK products after this. Hopefuly Daz can get more and more products from other manufacters.
heatware
ebay
  #183 (permalink)
Old June 14, 2011, 01:45 PM
Dazmode's Avatar
You can mount HK on old EK mount system.
I just RMA as everybody else for copper versions.
Orange Build: Final Video
HTPC Build: Final Video
  #184 (permalink)
Old June 14, 2011, 01:54 PM
Hopefuly for your sake the market for EK products doesnt dry up.
Comparing my new AC gtx580 block to my EK 580 block there is a huge discrepency in workmanship. I will never purchase EK ever again.
heatware
ebay
  #185 (permalink)
Old June 26, 2011, 06:51 AM
KaptCrunch's Avatar
since EK plated WB's are paper weights have any of you sawed eddys blocks in half yet...to see whats really inside. with all this testing going on is only the......... the top layer being tested
  #186 (permalink)
Old June 26, 2011, 08:22 AM
chrisk's Avatar
Folding Captain
Did Raider ever get that analysis back yet? Figured I would see all kinds of posts about it by now.
Fold for team #54196
  #187 (permalink)
Old June 26, 2011, 09:26 AM
KaptCrunch's Avatar
don't know but I don't need a test to know that eddy went cheap ...check your note$ eddy
don't judge a chunck of metal for its finish is covering some other material
  #188 (permalink)
Old June 29, 2011, 05:09 PM
chrisk's Avatar
Folding Captain
Looks like EK used good copper and good nickel in their blocks, according to Red Raider's analysis:
RRTech...The SOURCE for Extreme Liquid Cooling - View Single Post - EK - Copper Chemical & Metallurgical Analysis
Here is a quote from Red Raider on his analysis of the findings he got:
The two samples I sent off to IMR Test Labs, meet/exceed the chemical requirements of UNS-C-11000 for a CDA110 electrolytic tough pitch copper. EK's copper, used in these two samples, is 100% legit.
The plating also appears to actually be clean nickel, with a coating of 12.7 microns, on the sample 480GTX, that was provided for testing. This is actually admirable, IMHO, as Eddy has continuously claimed a plating of only 5 microns thickness. We still have our previous evidence of porosity in the coating, which presumably results from poor surface preparation, and possibly from the nickel plating process itself (e.g. the plating solution was not of the 'leveling' variety).
Anywho, it was an interesting exercise to see if something was up with the metals.
  #189 (permalink)
Old June 29, 2011, 06:07 PM
matari's Avatar
Hmm, that was interesting read. Turns out that I was wrong; EK uses high quality copper for their blocks. The nickel was 12 microns thick, not 4 that eddy stated. turns out the issue was indeed caused by a flawed plating process. If Eddy would have admitted to this, then EK would not have been in such bad shape.
  #190 (permalink)
Old June 29, 2011, 09:11 PM
The machining is being done too fast / sloppy, the copper of that rating is one of the hardest forms there is. It's not like standard milling copper that has added impurities to make it easier to work, so there's at least part of the problem (and why some of the blocks look pretty horrid machining mark wise).
new database development build rocketboy2000 New Builds 12 July 11, 2011 11:10 AM
Web development testing platform required Synth O/S's, Drivers & General Software 4 June 18, 2010 07:25 PM
Are there any jobs in game development now or in the next 4-5 years? andynerd Gaming 0 June 3, 2009 06:15 PM
Gaming/Development Pc ! ddrmanxbxfr New Builds 3 January 5, 2009 03:57 PM
Slow development of a new system gsp5322 New Builds 10 August 14, 2008 05:01 PM
