Old May 21, 2011, 06:15 PM
chrisk's Avatar
Folding Captain
Default HW Labs Black Ice SR 1 fan recommendation (and 800D upgrade)
Hey all;
Have some clicking and other issues with the Scythe fans currently on my SR 1 radiator. Year and a half old and I think they are wearing out.
I am looking for 6 fans for the rad, which will be connected to a Lamptron touch controller.
Here is what I am looking for:
1. Black in colour. I could put up with some red or white (ie. the fins), but would prefer all black.
2. Quiet
3. Available at NCIX, Canada Computers,or Dazmode.
4. Will be used in push-pull config on the 360mm rad (black ice sr 1)
Also, looking for absolutely all black fans for the Corsair 800D (three 140mm fans).
Thanks for any and all help!
Fold for team #54196
Old May 21, 2011, 07:32 PM
Thermalright X-Silent fans can be PMed to $6-8 at NCIX. I'd only recommend the 140mm ones though, the 120mm fans lack the static pressure for good rad performance.
Old May 21, 2011, 08:02 PM
JD JD is offline
I use Gentle Typhoons on my SR1. Though they're black/grey but they work great and are pretty much silent (I have the 1450RPM model).
Old May 22, 2011, 09:09 AM
lowfat's Avatar
The Gentle Typhoon 1850's are as good as fans come at the moment. They have better motor noise than the rest of the GT's. However they aren't black.
Old May 22, 2011, 10:10 AM
Keywork's Avatar
I personally recommend getting some Scythe S-Flex fans in either the 1200 or 1600 RPM variant. Great rad fans!
Old May 22, 2011, 11:39 AM
Nothing a can of Krylon Fusion and an hour can't solve. My GT's are red :)
Old May 22, 2011, 11:59 AM
lowfat's Avatar
Is it easy to remove the blades? I would love to paint mine white.
Old May 22, 2011, 12:31 PM
I use the scythe s-flex on my sr1 with a fan controller.
heatware
ebay
Old May 22, 2011, 01:13 PM
JD JD is offline
The newer high-speed models are full black though.
Scythe Gentle Typhoon Black Edition 3000RPM 83CFM @ 36db Fan Scythe Gentle Typhoon Black Edition 3000RPM 83CFM @ 36db Fan [D1225C12B7AP-29] - $23.99 : DazMode, Canadian PC Water Cooling and Modding Store
3000 RPM is the slowest model though.
Old May 22, 2011, 01:48 PM
Pretty easy, just watch the clip ring doesn't go flying, it is TINY and easy to lose.
Got it, hairdryer works well:
120mm Gentle Typhoon - Vinyl Dye Project - Overclock.net - Overclocking.net
And a good youtube video on it:
YouTube - ‪Worklog #4 - Fan Painting‬‏
Black ICE Friday (montreal) CMetaphor Off Topic 13 November 26, 2010 01:00 PM
[FS] Hardware Labs Black Ice 480 GTX Gen two Xtreme Rad Chromey Buy/Sell & Trade 7 November 17, 2010 07:57 PM
LF: Black Ice Xtreme Rads chibi_man Buy/Sell & Trade 2 September 2, 2008 04:06 PM
Black Ice Radiators, which one? Kopi Water Cooling 8 October 19, 2007 08:54 AM
HW labs Blck Ice GT-Xtreme performance Babrbarossa Water Cooling 4 April 18, 2007 09:31 PM
