Old May 12, 2011, 10:25 AM
Talking Options...
Hi all,
And my first post I'm in the planning stage of watercool my newly acquired comp.
Option 1:
XSPC single Reservoir> MCP655 Pump(reservoir mounted)> 360 Rad> Proc> Gfx Card.
Option 2
XSPC single Reservoir> MCP655 Pump(reservoir mounted)> 360 Rad> Proc> 120 Rad> Gfx Card> Gfx Card.
Should I just buy the 120 Rad now and put in the loop and just get the 2nd card later when I have enough money ? Or don't worry about the 2nd Rad at all?
Would I need to add another pump into the system? since pressure will drop if I added 2nd Rad to the system
I guess, another option, would be to go for dual pumps/loops but that would complicate the process.
I'm trying to keep it as simple as I can.
Please no bashing...Useful information/tips is greatly appreciated.
Thanks for your help,
Kong
Old May 13, 2011, 01:19 PM
Slaughter's Avatar
Hi Kong!
Welcome to the forums!
To start off, are you referring to the computer in your Specs?
If so, is there a need for Crossfire? Do you intend to fold or is this for gaming only?
I personally would start with just a 360 rad and add at a later date. If you are going for maximum cooling, then perhaps consider a push-pull configuration? Or are you trying to keep it silent at the same time?
Old May 13, 2011, 07:35 PM
Hi and thank you!
If you're talking about the comp's specs on my details then yes.
I'm planning to get 2nd card to crossfire for gaming/folding. Think it's worth it?
Don't think my case can accepts the push/pull setup, too thick. I want it to be silent so no revving of fans...lol, it was annoying when benchmarking the system with 3Dmark11...sitting about 8ft away and i can hear the fan going real good
what are the payment options bc_tileguy Off Topic 3 October 17, 2010 02:50 PM
DDR2 options? technix RAM 8 July 17, 2010 09:04 AM
RMA: What are my options? Gaston Troubleshooting 7 March 22, 2010 12:34 AM
Joystick Options lcdguy Gaming 4 March 5, 2009 06:57 PM
Options.... if any? 3.0charlie O/S's, Drivers & General Software 16 July 8, 2007 10:20 AM
