Old May 8, 2011, 07:41 AM
Default Newbie to watercooling
So last year I built myself what I believe to be a pretty sweet system. Just started to get into overclocking so I went out and got a Asus Crosshair formula 4 board matched it up with a 955BE some Corsair Dominator 4g kit at 1600, and a GTX460. My case is a Thermaltake Spedo that I got used and I went out and got a Thermaltake SpinVT cooler. All in all pretty sweet enough you would think, but in the back of my mind I wanted to try water cooling, and with an addition of a cat with long hair that get everywhere, I decided to switch my case out to a lian-li PC-9f looks more elegant then the crazy transformer spedo.(it is now in the living room) Also I could tuck a rx240 rad behind the front fans by removing the hard drive cages, I have a ssd and plan this summer to try my luck with a Revodrive x2. (so no need for the cages anyway)
Well okay now that you got most of my background my true question, how well does a two core rad with a push pull perform in your cases will it cool a cpu and a gpu well enough and could i get away with cpu and two gpu on this small rad or would i be better off with just cooling my cpu and let the gpu be air cooled.
I would like to try my hardest to get a 4.0g or more out of my cpu.
What do you guys think.
Old May 8, 2011, 11:38 AM
lowfat's Avatar
It depends on the fans. With low speed fans you may have rather high water temperatures, meaning higher CPU & GPU temps. Honestly your best bet would be to just water cool the CPU. It has the most benefit from being water cooled anyways.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old May 8, 2011, 12:05 PM
sweet thanks thats what I was thinking, plus saves on money
Newbie needs help. Bores Easily New Builds 5 December 15, 2009 03:32 AM
Newbie here. kav New Builds 78 November 6, 2008 08:04 AM
Help with wiring - again newbie kav New Builds 10 November 6, 2008 06:56 AM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
Newbie To Dc jinthabestmc Off Topic 1 June 6, 2008 02:28 AM
