Old May 5, 2011, 11:37 AM
Dazmode's Avatar
Default How much woudl you pay for extreme thermal pad?
Hi guys,
I'm researching extreme hightech market for thermal pads, but prices are spooky. For example thermal pad with 14x higher thermal rating then what you get with your GPU waterblocks can cost $40 a piece vs $5 for usual pad.
What you guys think? Crazy?
Orange Build: Final Video
HTPC Build: Final Video
Old May 5, 2011, 11:45 AM
lowfat's Avatar
I definitely wouldn't pay the difference. It isn't as if a better thermalpad is going to make your ram clock all that higher or anything.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old May 5, 2011, 11:55 AM
MacJunky's Avatar
It is kinda crazy imo, but I would be willing try one of those in my WC'd lappy. However the pump failed and I have not figured out how I want to set it up again if at all.
For me personally it boils down to if I really need it or not.(or if I am in an excessive mood)
Also, how rip/crumble resistant are they? Because if they turn to shit after the first application then they can bugger right off. Same goes for if they leak everywhere. Not cool.
Old May 7, 2011, 04:28 PM
Don't know if you checked out this site Daz (they're a bit off the map you might say) Chooyu Chemical, Your Thermal Solution Provider! they have a whole lot of pads to choose from...depends on cost, resellers, etc.
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
Old May 7, 2011, 04:35 PM
Dazmode's Avatar
I have not seen that one, but they make low-mid range pads. Top pad is "only" 7 Wmk, I looking into double and triple of that number. Still better then standard pads that are under 1Wmk.
Old May 7, 2011, 04:40 PM
well,if you were to setup a little demo,maybe you would get a more definitive answer?
i mean, lets see what were missing for the 35 dollar difference
Old May 7, 2011, 05:23 PM
found another one for you Daz, (Thermal Conductivity: 50.2 W/m-K) THERMAL PAD TO-220 .006" KAPTON - 175-6-220P
here is their main page Armacell Thermal Conductivity, Flexflyte Thermal Conductivity
Homer J. Simpson
Old May 7, 2011, 06:13 PM
Plus one more...Coollaboratory*Liquid MetalPad - the innovation of cooling for High-End sytems
Homer J. Simpson
Old May 7, 2011, 07:32 PM
dustin1706's Avatar
I would be willing to pay $40 for a thermal pad if there was some comparative testing (by a reputable person, AKA not the manufacturer) showing that there is an actual difference in real world temps. I mean, if you are spending the money for the water cooling for your GPU, you may as well go all the way.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
[WTB] Sandisk Extreme/ Extreme Pro 16GB SDHC card Dashock Buy/Sell & Trade 1 April 30, 2011 11:40 AM
mouse pad for a G5 Rescue119 Peripherals 7 April 26, 2010 04:40 PM
Thermal Pad vs. Thermal paste? RainMaker Troubleshooting 2 April 13, 2010 07:13 PM
Voltage regulator block (Thermal tape or thermal counpound?) Mavvens Water Cooling 5 August 8, 2009 06:56 PM
