Old April 23, 2011, 04:16 PM
Default MCP355 w/ XSPC Res-top enough?
Just wondering if one of these pumps would be enough for the following setup:
EK Supreme-HF w/ Plate 3
Swiftech MCR320
Swiftech MCR220
XSPC RX120
2x EK-FC480
It seems to work fine with my current setup (everything but the MCR220), but I'm just wondering if I'll need to look into a second pump should I want to add a third rad in.
Thanks in advance!
Old April 23, 2011, 08:32 PM
AmuseMe's Avatar
Rads are not very restrictive - at all. Personally, I would use two just for redundency, but you should be fine. Unless your running a bunch of 90-degree fittings or QD's.
Old April 23, 2011, 08:57 PM
Well, currently, I'm using three 45-degree fittings and a 90-degree fitting. When the MCR220 goes in, I'll probably be adding a second 90-degree. Would that be considered too much for the pump? I'm just looking at my options right now to see how much I'm going to need to put away for my WC setup this summer
Old April 24, 2011, 06:15 AM
AmuseMe's Avatar
I think you would be okay still. Those 355's have a good amount of pressure.
Old April 24, 2011, 06:44 AM
matsta31's Avatar
I had a 355 powering the following :
Switech 480 RAD + 220 RAD + 2 X Swiftech XT + 2 X FC GTX480 Blocks + 3 X 90 Degrees multioption, and I was ok.
Sold hardware again.....
Currently using WHS hardware....
Old April 24, 2011, 11:41 AM
Great! Definitely can't wait until I plug that dual rad in. Hoping for some sub-50 temps on my 480's :D
[FS] MCP355 + EK Res / Harmony 550 Remote Eniigmaa Buy/Sell & Trade 39 May 29, 2010 08:50 AM
[FS] MCP 655 + MCP 355 XSPC RES TOP + MCR 420 + MCR 220 X 2 + 9800 GX2 matsta31 Buy/Sell & Trade 40 April 1, 2010 06:37 AM
[WTB] XSPC res top + DDC 355 rai_polo Buy/Sell & Trade 16 November 4, 2009 06:40 AM
[FS] [SOLD] BRAND NEW Swiftech MCP355 w/ EK-DDC X-Top (Version 2) Liu Kang Buy/Sell & Trade 13 June 27, 2009 04:37 AM
XSPC Top and 150M Res with Thermochill Review cryostage Member Reviews 4 June 13, 2008 02:49 PM
