<~----> Damn.. i am so lucky -_- (problem with rasa waterblock) - Hardware Canucks
Old April 19, 2011, 05:41 PM
Default Damn.. i am so lucky -_- (problem with rasa waterblock)
One of the cpu waterblock (XSPC rasa kit) mounting screws doesn't fit in any of the holes of the plate.
Any suggestion ?
Thanks,
Old April 20, 2011, 01:31 AM
One suggestion Rush...send these photos to XSPC and have them send you a new set of mounting screws for the backplate.
Man; I've never seen one guy have so many (quality) issues with one kit, hope this ends well for you
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
Old April 20, 2011, 05:26 AM
Yeah that what i did, they gonna send me a set of mounting screws for the backplate. Oh man that doesn't count the problems i had with motherboard case standoffs lol one had not thread i had to go to a shop and get one.. combined with a plastic cap.. since the height was different. I just hope my system will start after i plug everything lol
Old April 20, 2011, 02:10 PM
mayb e its not going to :(
then u have to drain your loop and send it back in for RMA :(:(
Old April 20, 2011, 02:43 PM
lowfat's Avatar
You could always use a couple of zipties possibly in the meantime. Although the problems you are having w/ your block aren't anywhere what I went through w/ my Rasa. When I received mine it came w/ AMD mounting instead of Intel. Performance PC's mailed me Intel brackets but they forgot the main mounting plate. So they had to ship that out. It took over two months from the time I ordered it till I was able to use it.
Old April 26, 2011, 04:35 AM
Update: got my replacement set from XSPC. Its alright now the screws fit perfectly lol was definitivly a problem with them.. so now i can finish my build. Hope no more problems to come.
RASA 750 pump/res is rattling ? *updated* Rush Water Cooling 17 April 19, 2011 03:06 AM
Water block upgrade from XSPC RASA kit rugox Water Cooling 5 April 10, 2011 08:48 PM
Rasa 450 RS120 vs Rasa 750 RS240 Rush Water Cooling 8 March 29, 2011 10:28 AM
Some people are so lucky... Sushi Warrior Hockey 11 September 30, 2009 02:16 PM
Sometimes you just get lucky Nodscene O/S's, Drivers & General Software 3 August 18, 2009 12:39 PM
