<~----> Best way to clean nickel block - Hardware Canucks
Old April 15, 2011, 07:32 AM
Default Best way to clean nickel block
As the title says, what is the best way to clean a nickel plated water block?
http://www.thecomputermadesimple.com | The computer world in plain English!
Old April 15, 2011, 08:00 AM
to get the TIM off or corrosion ?
For TIM removal, I would think no different than a regular heatsink. Myself I use Lighter Fluid that really helps remove the TIM, then use 80% or higher Alcohol wipes or Alcohol with lint free towel or cloth.
Old April 15, 2011, 08:24 AM
If you're looking to clean 'watermarks' off, then good luck. I haven't found anything that really works.
Old April 15, 2011, 08:50 AM
I want to clean little deposits and "corrosion" (well nickel doesn't rust), but u know what I mean.
Old April 15, 2011, 08:51 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Bar Keeper's Friend.
[WTT] EK Supreme LT Nickel / Plexi r0k0 Buy/Sell & Trade 0 March 14, 2011 09:21 PM
[WTB] 5870 EK nickel plated acrylic model full cover water block (reference model) Lima Buy/Sell & Trade 4 October 4, 2010 10:33 AM
installing a Ek Water Blocks EK-FC4890 CF Nickel Full Cover Radeon HD 4890 GPU Block bc_tileguy Water Cooling 7 July 7, 2009 03:59 PM
[WTB] WC parts (pump, res, tubing, chipset block and 4850 compatible GPU block) donimo Buy/Sell & Trade 5 February 2, 2009 11:53 AM
