Old April 12, 2011, 10:45 AM
Default Really needed to use teflon or some tape on barbs thread ?
Hello,
Would like to know if its really needed to use teflon or some tape on barbs threads ?
Thanks!
Old April 12, 2011, 10:49 AM
G777's Avatar
Shouldn't be, and you might end up with little pieces of tape gunking up your loop
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
Old April 12, 2011, 10:56 AM
Originally Posted by Rush View Post
Hello,
Thanks!
Negative.
Do not use Teflon for barbs.
Old April 12, 2011, 11:16 AM
Alright thanks. Because i already made all the loop up lol
So this apply even with the RASA 750 kit ? I believe there no o-ring on those barbs.
Old April 12, 2011, 11:31 AM
matsta31's Avatar
All the barbs I have used have a tight enough fit with the tubing. You could laways leak test.
Keep the computer off and use another source of power or short you Psu. I did have a water leak occur on a powered off Mobo... I just made shure it was dry and had no problem afterwards.
Sold hardware again.....
Currently using WHS hardware....
Old April 12, 2011, 12:07 PM
3.0charlie's Avatar
Hello,
Thanks!
If there is an o-ring, no. The only barbs that I know of that NEED teflon tape are the Thermochill rad barbs with the G3/8 threads. They have no o-rings.
Hydro-Quebec is salivating...
Old April 12, 2011, 02:40 PM
i checked and they have o-ring thanks for the infos. I started my leak test so hopefully it will pass.
Old April 12, 2011, 07:18 PM
NPT threads don't seal, which is why there are o-rings. If you toss teflon tape on there all it will do is serve to create more thread space from sealing your o-ring properly, and pretty much just cause a leak down the line.
Thermal Tape bvsbutthd101 Air Cooling 16 March 10, 2011 01:51 PM
[WTB] 3/8 Barbs. rai_polo Buy/Sell & Trade 0 October 28, 2009 07:29 AM
[WTB] Thermal Tape punk_zappa Buy/Sell & Trade 0 June 28, 2009 02:15 AM
Barbs on rad up vs down cdn_Madrach Water Cooling 5 February 7, 2009 08:51 AM
Plumbers thread Tape Corpus Masochist Water Cooling 6 August 23, 2007 01:14 PM
