Here guys is what I have been working on the past few days. Loved the look of all the Corsair Obsidian 800D setups here, so I decided to do one myself. Loved the all-black interior. Was going to wait until later on, but with the Chimp Challenge coming up I wanted to get this done now.
List of parts. Most water parts purchased at Dazmode. Included all parts that some folks might wonder would work in a setup like this.
- SR1 Black Ice 360 rad, 6 fans (25mm top and 20mm bottom)
- Heatkiller 3.0 with backplate
- Swiftech MCP 655-B Pump, with EK D5 X-Top rev.2
- EK Multioption tube reservoir, basic
- 1/2in ID tubing
Rig parts:
- Asus Rampage III Formula
- i7 970@4.0Ghz
- 6GB Mushkin Redlines
- 2 x Evga GTX 460 1GB
- Corsair AX1200 watt PSU
- X-Fi Titanium
- Hauppauge 2250 PVR
- Corsair 800D, stock fans
- OCZ Vertex 2 240GB, and Vertex 120G, and WD Black 1GB
- LG Blu-ray rw
All these parts
weighed 63lbs when complete. I have not handled anything this big and bulky since Perineum's mom stopped by.
This is the finished product. Sorry about the pictures it was done quickly on my phone:
This is a few notes I took for others looking at this build with similar parts as myself:
I needed a place to put the MCP655 pump. Thankfully, the EK Top allowed me some options as to where the outlet would be from stock. I decided to take the small cover off the bottom hard drive tray, and use the unused space for the pump. I used double-sided tape to secure it to the bottom for now, as I could not attach it to the cage in a manner I felt was secure:
Another look from the from of the case with front bezel off:
The above picture shows how I could access the speed controller of the pump if I wish.
Next, I had to attach the reservoir. I decided I would use one of the E-ATX motherboard mounting holes to attach the res. Here is the hole I used, as there was plenty of clearance from the motherboard:
Then, I used a couple of EK reservoir mounting kits (Dazmode purchase again) like these:
Then I put two of the together so that it attached to the reservoir like this:
Then I mounted it like this:
I used the PCI-slot thumbscrew that came with the case (ie. normally used to secure a video card) that fit into the motherboard mounting hole perfectly. Black, and comes with the case. I would like to add a small nut at the back when I find one though.
This is a closer look at how the reservoir and pump looked when done:
Besides the crappy picture quality, seemed to work pretty well.
I was really impressed with all the space at the back of the case, behind the motherboard tray. Below, you will see that I was able to fit a power splitter that I was able to attach a molex power cable, and 6 radiator fans. I was able to close the case with this installed:
I attached the above power splitter with double-sided tape.
Here is a look at the rat's nest of cables when I was done the build...I was not too careful here to be honest:
Here is how it looked with the back on (a tight fit but no problems, except a bad picture):
Those are the only things I could tell anyone that might interest those looking to do a build with this case. Options for the pump, and lots of room behind the tray. Would fit a 360mm rad in a push-pull no problem.
A few more pics to finish up...love this case, and very good quality!
Great case and I love the all-black!
Temps, Comparison to the ATCS 840:
So far, compare to my Cooler master ATCS 840 this rig was just in, my temps are equal for the cpu (~50c folding), and my northbridge temps are 10c lower (not sure why yet...~55c for the 800D, 65c for the ATCS...will have to watch this as I thought the ATCS was better for air movement). temps for the GTX 460s are the same as the ATCS (~35c idle, 60c load).
