Old April 9, 2011, 08:21 PM
CTA's Avatar
CTA CTA is offline
Default switech mcp35x res
i am gave up with stupid ek ddc dual top... and crappy mcp355... so i am going to get mcp35x from ncix for 85 (Pm from dc)... but... they seem not carry res...
so where can i buy res (MCP35X Reservoir) for mcp35x? cheap is better... ;p
ps i am also to get hsf one... see MCP35X-HSF.. (of course without fan)
Old April 9, 2011, 10:30 PM
Dazmode's Avatar
Bit off topic, but isn't MCP35X just MCP355 with different top?
Orange Build: Final Video
HTPC Build: Final Video
Old April 9, 2011, 10:48 PM
CTA's Avatar
CTA CTA is offline
no its completed re-design... see MCP35X
Old April 9, 2011, 11:17 PM
lowfat's Avatar
It is a DDC 3.25 however it has PWM controller which no other pump has. Pair it up w/ Speedfan (as long as your motherboard has a PWM header) and you can easily control the speed of the pump via software.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old April 9, 2011, 11:19 PM
mataribot's Avatar
Daz is correct for the most part. The only thing that can not be confimed is the quality of the parts. If the OP wants A HQ pump that last years he is not gonna find it with lain ddc or d5. He is going have move up the food chain. But I am not sure it is really worth it in the end run.
Old April 10, 2011, 09:51 AM
Dazmode's Avatar
BTW EK has cylidrical DDC-Res combo too.
Ok, so this is 18W standard DDC with PWM option enabled + hyped Swiftech's own top. I wouldn't expect miracles from MCP355 upgrade. From reviews at FrozenCPU shop MCP35X has only 3.5 stars
Old April 10, 2011, 11:53 AM
CTA's Avatar
CTA CTA is offline
try other reviews...
Swiftech MCP-35X & Reservoir martinsliquidlab.org
[ User Review ] Swiftech MCP35X Pump + Reservoir - XtremeSystems Forums
Swiftech MCP35X | Skinnee Labs
mcp35x is hassle-free... and still covered by warranty...
Bay Res. Vs. Tube Res. for dual loop Amarthfea Water Cooling 7 February 24, 2011 03:31 PM
Would this work on mcp35x? Mekaw Water Cooling 3 February 18, 2011 01:40 PM
Swiftech Unveils New High Performance MCP35X Pump. FiXT Press Releases & Tech News 5 September 16, 2010 08:52 PM
Home Made Res... Chromey Water Cooling 3 February 18, 2010 08:18 PM
[WTB] 1/2" G1/4 Barbs, MCP35X XSPC or EK Top, fans andenario Buy/Sell & Trade 0 December 19, 2009 10:12 AM
