Old April 7, 2011, 05:22 PM
Default rubber tape thing on backplate of h50
When i was taking the back plate off of my motherboard i rippled that adhesive tape thing that came with it, as i will be reinstalling it i need more, or do i? who do you think would sell this stuff the cheapest
Old April 7, 2011, 05:41 PM
just use the one that came off
Old April 7, 2011, 06:35 PM
Deton's Avatar
you can pick up 3M two sided tape at any hardware store. Even WalMart sells this stuf.
ECS P67HA| i7 2600K @ 5000Mhz | 8GB GSkill RipJawX | Palit HD4870 Sonic Dual | Enermax 900W | Custom H20 | Tech Station
Old April 7, 2011, 06:57 PM
what i more or less was looking at was "do i even need it"
Old April 7, 2011, 08:23 PM
Slaughter's Avatar
I believe it's there for mounting convenience if I'm not mistaken. It just holds the mounting plate in place so you can assemble it from the front.
Old April 7, 2011, 09:13 PM
Deton's Avatar
personally, you can live without it. It's just make easier to mount the cooler if you have one because you don't have to hold the backplate with one hand and while trying to mount the pump/block with the other hand. I'm talking about when you try to do the installation with the mobo in vertical position (mobo still installed on the mobo tray with backplate cut-out).
Old April 7, 2011, 10:10 PM
coleo's Avatar
I am going to go with you need it.
i did not use mine on first install as the hole in my mb tray held the piece on the back right in place.
i had a cooling issue for a few days and a couple re paste and re seats did not apply.
so i put them two pads in and there was a definate improvement to how the plate seems to pull down on the pump and water block.
now i didnt peel the sticky tape on the mb side for just such an occurance though
Thermal Tape bvsbutthd101 Air Cooling 16 March 10, 2011 01:51 PM
Mouse Feet Rubber Dealios headsh0t Peripherals 5 August 22, 2010 09:47 AM
Double sided tape for backplate. Lima Air Cooling 7 October 31, 2009 08:45 PM
[WTB] Thermal Tape punk_zappa Buy/Sell & Trade 0 June 28, 2009 02:15 AM
Where can I buy some rubber strips for anti-vibration inside pc? appplejack Peripherals 5 January 17, 2009 06:23 AM
