Originally Posted by Ging9 Just out of curiousity, when you say you swapped out fans, what did you go with? |
I've done multiple swaps (I have two Eco's, an H50, and H70).
For the ECO's I opted to go with the Silverstone Penetrators. Very nice Fan if you ignore the cost
On my H50 and 70 I popped on R4's from Coolermaster. They actually don't make as much noise on a Rad as they do when mounted on the PLexi or Lexan of a Side panel. So they tend to be fairly well mannered.
If you really want to bring the silence you can grab some GELID fans, they are nice and silent. Nexus or Zalman have a few types that work as well.
The main thing to remember is that with most (Not all) fans you will sacrifice some performance (or gain some) depending on the speed and static pressure it has.
And we all perceive noise differently, and cases ressonate sound differently.
My thoughts,
ST
