Old April 19, 2011, 08:50 PM
Originally Posted by Eluder View Post
I am actually currently thinking of picking up the H60 as a replacement for the 212+ as well, but on a 2600k at 4.5GHz.
I am running the 212+ with 2x Noctua NF-P12's in a push/pull config and it is pretty darn quiet, don't think I can hear it over the other fans in the system.
The 212+ doesn't block any of my DIMMs on my board, so no benefit in going to the H60 from that perspective, but I was hoping for improved cooling with the H60 with similar noise.
I would move the 2x Noctua's to the H60 (does the H60 support 2 fans?), but do you think it would be worth it?
Don't know about the H60 but the H70 should fit the bill. Currently have a 24/7 cruncher running WCG, 2600k @ 4.4GHz and the temps are; CPU=38c Cores are between 48-55c. (AIDA)
Old May 17, 2011, 02:43 PM
slippy's Avatar
H60 warranty is now 5 years instead of 2!
Corsair Stretches Hydra Series H60 Cooler Warranty to 5 Years - HotHardware
AMD A10 5800K | MSI FM2-A55M-E33 | Asus 7750 1GB
4GB G.SKILL Ripjaws | 500GB WD Blue; 2TB WD Green | Corsair CX500
Cooler Master Elite 430
Old June 17, 2011, 07:19 AM
Any one know if it is possible to put a H60 on a videocard GPU? Is it good enough? (I'm thinking that it could be a fast and cheap solution to cool down my HD5870... with elss noise!)
TIA
Best 120mm fan for H60 Ging9 Water Cooling 3 April 12, 2011 06:56 AM
Antec Kuhler 620 vs Corsair H60 Thread slippy Water Cooling 5 March 11, 2011 09:04 AM
Corsair Announces First Shipments of Hydro Series H60 FiXT Press Releases & Tech News 11 March 2, 2011 11:06 AM
iOS4 user impressions Synth iPhone & iPods 11 July 13, 2010 11:32 AM
VX Revolution - First Impressions Mr. Friendly Peripherals 0 January 3, 2008 10:27 PM
