Old April 3, 2011, 10:50 AM
Default 240mm rad enough for CPU?
Is it? i7 930 wanting to overclock.
And maybe later for a GPU (maybe overclock too)
Old April 3, 2011, 11:06 AM
My slim Swiftech 120mm rad is cooling an i5 and a GTX570 (both stock) without breaking a sweat, you'll be fine.
Edit : 570 not 470
Old April 3, 2011, 11:58 AM
lowfat's Avatar
For a single CPU yes. Unless you are going to a balls to the walls overclock that is. If you add the GPU it will depend on what fans you use. GTX470 will add a lot of heat to the loop.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old April 3, 2011, 12:00 PM
I think I'll be off better with 360mm thx
Old April 7, 2011, 01:36 PM
Deton's Avatar
Yes it does for CPU only even with overclocked i7 90x, a 240mm rad can dissipate at least up to 300w of heat (depend on fan RPM).
360mm rad is a little bit overkill for CPU only. However, you have a lot of headroom left for add on the other compoments (mobo or GPU).
ECS P67HA| i7 2600K @ 5000Mhz | 8GB GSkill RipJawX | Palit HD4870 Sonic Dual | Enermax 900W | Custom H20 | Tech Station
Old April 7, 2011, 01:47 PM
Slaughter's Avatar
Might as well buy the 360 now instead of looking for one later or running multiple rads. ;)
240mm rad vs 360mm rad BFighter Water Cooling 1 March 20, 2011 01:59 PM
[FS] EK 240mm Radiator Fudd Rucker Buy/Sell & Trade 3 December 15, 2010 01:13 PM
Pump -> CPU or Rad -> CPU Keywork Water Cooling 14 November 11, 2010 09:13 PM
2X120mm rad dual gpu+cpu loop nckid4u Water Cooling 19 May 12, 2009 05:05 AM
[WTB] 240mm Rad,1/2 inch fittings g1/4t,nb,sb block renoracer Buy/Sell & Trade 2 November 26, 2008 03:39 PM
