Old March 28, 2011, 05:11 AM
Default Rasa 450 RS120 vs Rasa 750 RS240
Hello,
Would like to know if anyone tried the rasa 450 and 750.. is there much of a difference in performance ? i only want to watercool the CPU.
Thanks.
Old March 28, 2011, 08:31 AM
sswilson's Avatar
I'm not familiar with those kits, but I'm more concerned about the second part of the PN (120 vice 240) than the 450/750. If you're only going to go with a single fan rad, you might as well stick with high end air cooling.
Old March 28, 2011, 08:35 AM
AmuseMe's Avatar
Or just get the Corsair H50/ H70 :) I'd say get a kit with a triple :)
Old March 28, 2011, 10:01 AM
What's wrong Rush, were you not getting the answers you were seeking in this thread Getting into watercooling ? ?
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
Old March 29, 2011, 04:15 AM
No. That not it. I am just trying to find options for my case with the ASUS P8P67. This doesnt seem to be easy in my case i have to figure out what the best emplacement for the radiator.
Old March 29, 2011, 07:12 AM
As Mekaw pointed out in the other thread; you could place the radiator outside (on the back, using the supplied hardware) of the 600T; but instead of trying to use the usual tubing holes to route the hoses inside your case, use one of these Slot Pass Through Bracket with Dual F Fittings Slot Pass Through Bracket with Dual F Fittings [BKT-PCI-G] - $14.99 : DazMode, Canadian PC Water Cooling and Modding Store to link the hoses from the outside to the inside.
Homer J. Simpson
Old March 29, 2011, 09:55 AM
I actually used this. because I read there are possibilities of leak if you use the one you've linked and it only cost around buck fifty from ncix
Old March 29, 2011, 10:20 AM
Much better choice Mekaw-thanks (and MUCH better price).
Homer J. Simpson
Old March 29, 2011, 10:28 AM
Interesting! One more question... are there anything in the way between two pci backplate ?
[FS] iPhone 4 16GB $450 JoshOohAh Buy/Sell & Trade 1 March 24, 2011 08:27 PM
GTS 450 or HD 5770? technix Video Cards 11 September 15, 2010 06:37 PM
GTS 450 is out already? bvsbutthd101 Video Cards 49 September 12, 2010 02:29 PM
New build! going from a Pentium 2 450! Maculosa New Builds 3 November 4, 2008 09:13 PM
