Old March 26, 2011, 06:15 PM
Default Getting into watercooling ?
Hello,
Would like to know what i need to buy for a simple water cooling ? Will i have to spend more than 150$-200$ ?
Thanks.
Old March 26, 2011, 06:18 PM
KaptCrunch's Avatar
Originally Posted by Rush View Post
Hello,
Thanks.
simple meaning just the cpu
other is for what perpous? silent or 0C'n
Old March 26, 2011, 06:19 PM
Yeah just for the CPU. Would love it to be silent and i am about to OC. ACtually i would want a system that could go on ASUS P8P67 LGA1155.
Old March 26, 2011, 06:56 PM
lowfat's Avatar
An XSPC Rasa kit like this would likely be a decent enough for just a 2500k/2600k.
Rasa 750 RS240 Complete CPU WaterCooling Kit Rasa 750 RS240 Complete CPU WaterCooling Kit [RASA750KIT] - $149.99 : DazMode, Canadian PC Water Cooling and Modding Store
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 26, 2011, 07:18 PM
Yeah i saw this kit and it look awnsome. But i have a corsair 600t case would you think that fit with the asus P8P67 mobo ?
Old March 26, 2011, 11:54 PM
lowfat's Avatar
Honestly I do not know much about about a 600T but it looks like a dual radiator will fit at the top of the case w/o real issues. And the Rasa block w/ fit LGA1155.
Queen of Dreams WIP
Big Lian Li
Complete
Old March 27, 2011, 12:37 AM
600T WILL fit 240 rad up top, just not the dual width like RX series rad. xspc RS rad and swiftech mcr stuff will fit. you'll have to place fans on the other side of the grill, hence the reason corsair added removable top piece to accommodate 2 120mm fans.
Old March 27, 2011, 06:58 AM
Thanks for this info ! The main problem is the mobo top headsink.. hope it wont touch it i will be using a P8P67. Also, it is hard to assemble ? I believe there is a way also to test the loop before inserting the whole thing ?
Thanks.
Old March 27, 2011, 07:31 AM
I'm in the middle of putting together my first water cooling setup; using the Rasa 750 RX360 (not too different from the RS240-only bigger), there are a few places to go if you're just getting into water cooling + wanting to know more about the Rasa kit from XSPC.
1) Dazmode's Complete Watercooling Guide (part 1 - Part 8) YouTube - DazMode's Channel I watched his video guide over and over, so that I wouldn't be completely blind going into this experience
2) Dasmode's YouTube Channel (EK H30 vs XSPC Rasa 750) YouTube - DazMode's Channel
3) pureoverclock.com review of the XSPC Rasa750 RS240 XSPC Rasa 750 RS240 Water Cooling Kit
Although some have stated in the past that they have done a leak test before installing the setup in their computer; then you'll have to dismantle the setup to install it anyway, and this will defeat the purpose of doing the test outside (as there will be a chance of missing a connection during the 2nd install - leading to a leak).
I'm with the others (who will chime in soon); and say that it's best to install everything into your 600T, and perform the leak test then.
I found it very helpful also to read through the watercooling guide listed here Water Cooling Guide for Beginners Overclockers Tech (just skip past the parts about the equipment and go down to installing/ testing).
while you're on dazmode's YouTube Channel; take a look at some of his other vids, there's one for performing a leak test, among others.
Is it hard to assemble?
Not really; there's documentation showing how to install the CPU block (and a few other things), I didn't read through it, because I'm installing an AMD CPU, and it doesn't have any stuff regarding AMD in the install guide.
Just take your time installing everything; plus, you'll always have people here that will assist you whenever you need help
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
Old March 27, 2011, 07:34 AM
Alright thanks! I get a look at these. I am not rushed actually i still waiting for the others pieces to come in. Already got my case and PSU.
I am using a 650W psu and wont go SLI or anything. Do you think this is enough with such watercooling system ?
First Watercooling Project eXz Water Cooling 9 July 6, 2010 09:38 PM
Watercooling a 4850x2 Syl66 Case Mods, Worklog & Gallery 6 April 19, 2009 03:31 PM
Is WaterCooling for me? arekieh Water Cooling 10 October 20, 2008 05:50 PM
Watercooling Help EDMCR Water Cooling 24 August 3, 2008 07:24 AM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
