Old March 27, 2011, 09:00 AM
According to the pump specs; it uses just above 10 watts of power, as long as you're using a good quality, brand-name PSU, I think you'll be alright
Anybody else want to pipe in?
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
Old March 27, 2011, 09:08 AM
ANTEC TruePower 650W should be fine then.
Old March 27, 2011, 09:20 AM
Originally Posted by Rush View Post
Thanks for this info ! The main problem is the mobo top headsink.. hope it wont touch it i will be using a P8P67. Also, it is hard to assemble ? I believe there is a way also to test the loop before inserting the whole thing ?
Thanks.
should be fine, it just clears cpu fan header on mobo up top so it'll clear it
Old March 27, 2011, 10:00 AM
Sorry, but what you mean by it just clears cpu fan header ?
Old March 28, 2011, 12:18 AM
here's my old setup with 240 rad up top and external rad.
you see the fan header? fan header is the 3 or 4 pin plugs on your mobo for your fans. in this case cpu fan header is 4 pin and usually up top near the edge of the mobo.
slim 240 rad just partially blocks the fan header up top(white plug next to ram<left of> just under the rad). So I think it'll just clear your heatsink
HOWEVER, i think your major problem is the 8 pin connector on top left corner, on that mobo, I don't think there's enough space to plug
Old March 28, 2011, 04:51 AM
Damn you right. Erm. Why they did put it there.. that not awnsome. Well i still can put the rad outside the case since there is tubing holes. But the problem now is the desk size lol
Any others suggestions ?
Old March 28, 2011, 06:27 AM
Although it may seem less attractive; you may need to attach the radiator to the rear of the case, as in Mekaw's pic (the hose coming into the case from the outside-lower left of the picture).
I've seen quite a few cases (in various watercooling forums) where this can be done tastefully.
Homer J. Simpson
Old March 28, 2011, 11:43 AM
i find that problem with where corsair placed those 2 wc holes are terrible palement... I wish they put it up top instead of vertically on the side
here are couple of different setups i used.
first with mcr220 externally and another one inside.
then replaced external one with TA120.3
then i just got rid of 220 rad and modified 5.25" drive bay and fitted ta120.3 inside..
  #19 (permalink)
Old March 29, 2011, 04:16 AM
You wasn't able to pass the second watercooling tube in the hole ? but a watercooling tube isnt flexible ? its strange you had to pass by the pci cards holes. I mean, ive seen other setup with such vertical holes for water cooling tubing.. and i believe if they put the tubing holes there there much be a reason they must have tried it.
Anyway i am pretty sure i can't put the rad in the ceiling. Maybe in the top area with fans under ?
  #20 (permalink)
Old March 29, 2011, 07:22 AM
For starters; yes. hoses are flexible (bend radius depends on the thickness of the hose-smaller the hose, the tighter the bend).
Second; this is going to get confusing real quick, we're going to start getting cross-post answers on the same subject Rasa 450 RS120 vs Rasa 750 RS240 which is: "Best radiator setup for a 600T"
Homer J. Simpson
First Watercooling Project eXz Water Cooling 9 July 6, 2010 09:38 PM
Watercooling a 4850x2 Syl66 Case Mods, Worklog & Gallery 6 April 19, 2009 03:31 PM
Is WaterCooling for me? arekieh Water Cooling 10 October 20, 2008 05:50 PM
Watercooling Help EDMCR Water Cooling 24 August 3, 2008 07:24 AM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
