Old March 26, 2011, 03:58 PM
ipaine's Avatar
Default Fans for Corsair H50
Ok, so I have had the Corsair H50 for awhile. Considering I am redoing my build I am also wondering if I should redo my fans.
What I am wondering is if I should stick with the Scythe Gentle Typhoon, which are not PWM fans, or should I go with two of the Scythe Slip Stream Kaze-Jyuni PWM Fans? I should mention that I will have this in a push-pull setup. If I go with the PWM ones I will use a Gelid PWM Y cable adapter. Is it worth it to have PWM fans with the H50 and be able to control it using something like Fan Xpert that comes with my new Asus board. Or just is something like the Typhoon better even though it is at full speed and not controlled?
Peoples thoughts?
Oh as it is right now I get about 30-33 for idle temps with the Gentle Typhoons. As for load, I just did a quick test and having all 4 cores at 100% the temps hung right around 45. This is with my Q6600 oc'ed to 3.2GHz.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old March 26, 2011, 04:19 PM
You'll want high static pressure fans for optimal performance. The Slip Stream fans are perfect for exhaust fans and intake fans where there is no resistance; however, they're poor for situations where there is resistance directly in front or behind the fan, such as an intake with filter or in this case a radiator.
In other words, the Gentle Typhoons are a good choice.
Old March 27, 2011, 01:06 AM
Jackquelegs's Avatar
Stick with that you have. No point changing the Gentle Typhoons, since the Kaze Jyuni is just a poor fan in general.
Sleep on it, you'll realize you have no reason to change
Iapetos
Zephyranthes
Old April 12, 2011, 02:57 AM
The GTs you have are pretty nice fans and therefore leaves you with less room to improve on. On another note, if you want some leds on your fans for some cool lighting effects, have a look at Gelid wing 12s. These are pretty nice fans that also have PWM connection. I have them on my radiator.
[WTB] [WANTED] Corsair H50 Jelah Buy/Sell & Trade 2 August 8, 2010 10:22 AM
Corsair H50 vs CoolIT ECO Flemminr Water Cooling 11 June 28, 2010 05:02 AM
[FS] Corsair H50 mattlef Buy/Sell & Trade 1 January 8, 2010 06:18 PM
[WTB] Corsair H50 sinticfury Buy/Sell & Trade 6 December 20, 2009 01:29 AM
Corsair Showcases Computer Build with the Corsair 800D and H50 FiXT Press Releases & Tech News 2 October 2, 2009 12:22 AM
