Old March 24, 2011, 03:08 PM
Question Connecting Multiple PWM Fans
I'm just starting to put together my water cooling setup (triple XSPC rad with 6 fans in a push/ pull configuration), and stopped to think a minute about connecting all the fans to my motherboard.
So here's my thoughts and question:
I want to connect up to 6 fans Cooler Master 120mm Long Life Case Fan, Blue LED at Memory Express Computers using these cables GELID PWM-Y Cable Adapter at Memory Express Computers According to the description; " Connect 2 PWM fans to your mainboard’s CPU socket. Use multiple Y cables to connect a series of up to 5 PWM fans and provide as much extra cooling as desired ", how do I find out if all these (connected) fans will actually work as their supposed to without blowing my motherboard?
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
Old March 24, 2011, 04:03 PM
Prolab's Avatar
It will work.
Im currently using this to control 3 Gelid PWM fans whenever the CPU hits 40C (via CPU pin out).
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
Old March 24, 2011, 04:58 PM
usually the fan connector is rated for a specific amperage, it should be mentioned in the manual
Old March 24, 2011, 06:10 PM
Default ASUS M3A79-T Deluxe
This is a direct quote from the manual for the motherboard listed above:
" CPU, chassis, and power fan connectors
(4-pin CPU_FAN; 3-pin CHA_FAN1; 3-pin CHA_FAN2; 3-pin PWR_FAN)
The fan connectors support cooling fans of 350mA-200mA (24 W max.)or a total of 1 A~7 A (84 W max.) at + 12V. "
So if I'm to interpret this correctly; then each fan attached to the fan connectors can be between 1 - 7 A each, for a combined total of 84 watts maximum.
Unfortunately, the manual doesn't state the maximum wattage permitted for just the PWR_FAN or CPU_FAN connectors.
The fans in question are rated @ .35 A or 4.2 watts (+/- 10%) each, so combining 3 on the CPU_FAN connector and 3 on the PWR_FAN connector, would be a total of 12.6 watts (+/- 10%).
Homer J. Simpson
Old March 24, 2011, 06:52 PM
KaptCrunch's Avatar
wire in parralle not series i see your @ 100% of control cap 24watts
1 fan = 4watts x6 = 24
amps total of 6 fans = 2 amps over rated by 1.650 amps
Old March 25, 2011, 02:37 PM
I appreciate all answers (so far) received
What I'll probably end up doing; is connect 2 fans to the PWR_FAN connector, and 2 fans to the CPU_FAN connector, then 2 fans on one of the CHA_FAN connectors (either #1 or #2).
That way, I won't be overloading any of the fan connectors on the motherboard; with the rest of the case fans, I'll probably connect those using a molex connector (or 2).
Homer J. Simpson
Old March 28, 2011, 05:00 PM
KaptCrunch's Avatar
here a handy pie chart for electric units when making projects
Old March 28, 2011, 06:08 PM
So...my connecting 2 of the fans listed above (to the Gelid PWM Y cable); then to either the CPU or Power connector, will or will not work.
I'm just a simple (old) guy trying to make my PC a little bit happier and cooler
Homer J. Simpson
Fan controller and PWM fans homer98 Air Cooling 4 September 28, 2010 07:51 AM
How to connect Delta PWM fan? G777 Air Cooling 4 June 15, 2010 10:11 PM
PWM Y Connectors impruv Air Cooling 0 January 25, 2010 08:16 AM
4 Pin PWM Fans connect to molex? chrisk Air Cooling 4 December 16, 2009 10:05 PM
can PWM fans be used without PWM controllers? solaris10 Air Cooling 0 February 4, 2008 10:29 AM
