Old March 22, 2011, 06:34 PM
Default 6950 1GB version waterblock?
hi, does anyone know if the waterblocks out right now would fit a 6950 1gb version? thanks
Old March 22, 2011, 06:51 PM
ZZLEE's Avatar
Witch card is it referance. ?
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old March 22, 2011, 07:35 PM
the XFX ones, and yes, i think they are reference. heres a link, 6950 1gb and 6870 1gb Same PCB??? Maybe be able to use Same water block??? - techPowerUp! Forums
Old March 22, 2011, 07:49 PM
ZZLEE's Avatar
K- Full Cover GPU Block for Radeon HD6970/6950 - VID-AR697 K- Full Cover GPU Block for Radeon HD6970/6950 - VID-AR697 [VID-AR697] - $149.99 : DazMode, Canadian PC Water Cooling and Modding Store
Old March 22, 2011, 09:36 PM
the 1GB version is different then 6950 2 GB versions i think?
Old March 22, 2011, 09:46 PM
ZZLEE's Avatar
Non referance PCB. Non referance cooler. {: " LINUS"
Old July 31, 2011, 11:40 AM
Trial Member
Default Same problem your having.
Hello all,
It seems as if the same problem that oksir is having is the same problem I have been experiencing as well. Were either of you able to find a waterblock for your XFX Radeon HD6950 1gb?
I have looked at many and it seems the EK one may only be for the 2gb version? Or am I mistaken?
I have pictures of the cards which I can provide it that would help find the correct blocks
Thanks,
KBundy
Old July 31, 2011, 12:43 PM
I used this form CoolingConfigurator.com (Submit New Hardware form) from Ek's website, they got back to me within a few (business) days with an answer.
To find out if the video card is a reference design; contact the manufacturer, they'll be able to tell you if the card you have is of reference design or not (I did this for my HIS HD6870, got answers from both HIS and EKWB in no time at all).
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
XFX Radeon HD 6950 XXX 1GB or MSI GTX 560 TI ? Rush Video Cards 17 March 26, 2011 07:30 PM
AMD Radeon HD 6950 1GB Review Comment Thread SKYMTL Video Cards 17 January 31, 2011 05:14 PM
AMD Radeon 6950 1GB Shedding Pounds [Updated] FiXT Press Releases & Tech News 13 January 19, 2011 02:37 PM
HD 6870 vs upcoming HD 6950 1gb RedTauren Video Cards 2 January 3, 2011 11:02 AM
