Old March 19, 2011, 02:27 AM
nasrott's Avatar
Default Apoge GTX and SB
Just bought a new sandybridge setup yesterday and semi tryed to install the 1156 hold down for it on my 1155 board nothing seemed to fit, am I missing something? Do i need a new holddown bracket?
Thx Nas
Old March 19, 2011, 09:18 AM
lowfat's Avatar
You use the LGA1156 bracket.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 20, 2011, 12:53 AM
Thx Nas
Just trying to clarify things a bit
Did you buy the Sandy Bridge CPU and a 1156 board (and nothing fits right); or did you buy the CPU and are trying to fit it onto a 1155 board...big difference; because Sandy Bridge CPU's only fit on 1156 boards, they're not compatible with the older 1155 boards.
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
Old March 20, 2011, 07:59 AM
nasrott's Avatar
well the 1156 holddown on my swiftech kit will not fit the 1155 board, bman, sandy bridge is lga 1155 the 1156 is the older board, have no problems with the cpu and board is my water cooling kit holddowns that is the problem dont have a setup for lga 1155
Old March 20, 2011, 10:03 AM
lowfat's Avatar
Sounds like you are using the wrong backplate. I use an XT on my Asus P8P67 Pro w/ no issues.
Queen of Dreams WIP
Big Lian Li
Complete
Old March 20, 2011, 02:06 PM
nasrott's Avatar
ya was using the wrong holddown and backplate seems the 1155/56 holddown kit was an option I didn't have with my kit. Will order the proper one this week.
Old March 20, 2011, 02:57 PM
Apologies nasrott...
damn Intel and their #'s, must have been way too early for me, just got the #'s turned around
Homer J. Simpson
Old March 23, 2011, 02:26 AM
nasrott's Avatar
Np Bman, well bought a new block, parts for the gtx were not in stock, so grabed a new XT Apoge which came with the 1155 back plate and the holddown is universal now for all intel sockets.
Old March 23, 2011, 07:36 AM
Uhm.. what?!
Sandybridge only fits on 1155 boards and 1156 mounting brackets work on 1155 boards.
Old March 23, 2011, 02:08 PM
Originally Posted by enaberif View Post
Uhm.. what?!
Please see post made by myself March 20, 2011
Homer J. Simpson
