Old March 18, 2011, 06:29 PM
lowfat's Avatar
Default flow rate, overrated?
So I somehow managed to kill my two 18w DDCs. So I installed an Eheim 1250 in its place. The flow of the Eheim is ridiculously low. My flow meter shows 1.3LPM, which is around 0.35GPM. Which is way under the 1GPM which is generally suggested. Now the weird thing is that my CPU temperatures are pretty much exactly the same. The Eheim is also WAY quieter than the 18w DDCs.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 18, 2011, 06:56 PM
Fudd Rucker's Avatar
Thanks a whole lot , now I have to get a new pump lol. That one looks much better than mine, footprint wise.
I couldnt think of something snarky or interesting to put here this time around.
Old March 18, 2011, 07:06 PM
Jackquelegs's Avatar
HOWTO kill two DDCs? My word.
Anyways, flow isn't critical as long as your system was overkill to begin with. 1GPM is just a rule of thumb for new builds.
I ran on close to 0.2gpm before due to a small plumbing problem before (COUGH CLOGGED UP CPU BLOCK), and it didn't really make a difference in any of my temps including NB/SB and GPU.
Iapetos
Zephyranthes
lowfat's Avatar
An Eheim has a better footprint? This thing is HUGE.
The DDC's I bought had a yellow, black, red wire, and RPM. I think I effed up on wiring them and burned them out.
Queen of Dreams WIP
Big Lian Li
Complete
Old March 18, 2011, 07:10 PM
Yeah ahah, wanna use the Eheim? Say goodbye to your HDD bays.
That's unfortunate, did they both die at the same time?
Iapetos
Zephyranthes
Old March 18, 2011, 07:15 PM
lowfat's Avatar
No. I think I killed the first one the first time I powered up the machine. I noticed my flow was hovering around 0.8GPM so obviously one of the pumps wasn't working. So I tried to fix it and screwed up the other.
I am going to try to do the PCB replacement that is available on eBay. However they aren't meant for DDC3.xx so it may not work. But @ $15 a piece it is worth giving it a shot. I'd rather not have to spent another couple hundred on replacement pumps.
Queen of Dreams WIP
Big Lian Li
Complete
Old March 18, 2011, 07:20 PM
For sure, DDC's aint cheap...good luck! When all else fails, there's also ..this is hard...Air..cooling /wrist
Iapetos
Zephyranthes
Old March 18, 2011, 07:25 PM
lowfat's Avatar
No way an I going to remove my GPU blocks and reinstall the stock HSF's. Too much work. Eheims may not be performance kings but they are about as reliable as pumps come.
Queen of Dreams WIP
Big Lian Li
Complete
Old March 18, 2011, 07:28 PM
For sure, DDC's aint cheap...good luck! When all else fails, there's also ..this is hard...Air..2cooling /wrist
How dare you speak such blasphlemy here lol .
Edit: wasn't aware those punps were so big, pic didn't do it any justice.
Old March 18, 2011, 07:37 PM
coleo's Avatar
a slower flow rate wouldnt mean less cooling as water isnt a very fast heat absorber
just for example some high performance motors have to slow down water flow rates to get the heat out of the motor.
NEW REVIEW: Flow Test Dazmode Water Cooling 14 April 24, 2010 08:17 AM
[WTB] Inline Flow Meter chibi_man Buy/Sell & Trade 0 February 14, 2010 08:50 AM
most overrated/underrated manufacture? RedLight CPU's and Motherboards 19 June 22, 2009 03:18 AM
Crossfire requirements overrated? drewis Power Supplies 31 May 20, 2009 06:51 PM
flow restriction on 90 deg fitting? sswilson Water Cooling 8 September 26, 2007 02:41 PM
