Old February 4, 2008, 08:01 AM
zlojack's Avatar
I put an 80MM fan on the side panel and attached it with zip ties.
I have my TRUE mounted vertically with 2 fans
Old February 8, 2008, 02:12 PM
magictorch's Avatar
Quick question: The base plate is 42mm *40mm the heatpipes are arranged either side of the longest axis.
Is the cooling performance altered by different orientations due to the effect of differences in coverage on the cpu and alignment of pipes?
