Old March 11, 2011, 01:26 AM
CTA's Avatar
CTA CTA is offline
Default water in res tube
this might not normal to me... but i want to make sure...
a few days ago, i remember to pour the distilled water into the ek res v2 tube to almost full... so i stressed the computer at a couple time... prime 95, occt, unigine heaven, watching movie, playing movie, etc...
yesterday, its not same before... just little decrease... then today, it decrease again... but i cant find any leaking water somewhere...
is it normal? maybe it goes into vapour... eh?
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
Old March 11, 2011, 03:30 AM
sswilson's Avatar
This is a fairly new loop? If so, a slight drop in res levels is normal for the first little while as all of the air and microbubbles gets out of the system.
Old March 11, 2011, 04:08 AM
probably air bubbles working itself out of the loop, if it's new that's normal
Old March 11, 2011, 10:13 AM
CTA's Avatar
CTA CTA is offline
yes... just a few days ago...
should i pour more distrilled water?
Old March 11, 2011, 10:34 AM
martin_metal_88's Avatar
You can put more water into it. I would wait a week or 2 to make sure you have the final level and then fill the gap so you wont have to do it 5 time.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old March 11, 2011, 10:58 AM
CTA's Avatar
CTA CTA is offline
alright i will do what you suggest...
thanks again...
Old March 11, 2011, 11:07 AM
lowfat's Avatar
Is this while the system is powered on or off? If on, then it is normal for the water level to be considerably lower.
Old March 11, 2011, 12:21 PM
CTA's Avatar
CTA CTA is offline
of course always happen when it turns on...
and yes i notice that... but i only refer to water change in everyday or so while i use the computer...
Old March 11, 2011, 12:36 PM
lowfat's Avatar
Double check all your barbs and verify there isn't a leak anywhere. If there isn't then I really wouldn't worry about it.
Old March 11, 2011, 01:53 PM
mataribot's Avatar
In my opinion you probably still have air in your radiator. That might be part of problem. The first round of EK Multioption X2 reservoirs shipped with faulty O-rings. unfortunately, many vendors still have those reservoir in stock. Threads like this one pop up from time to time on XS and other forums. Put some toilette paper around the threads and check it after 6 hours of thermal cycling. If you have a leak, then you can rma it with EK, they have been good with replacing the bad o-ring. Make sure you don't mention pt nuke if you used it, it voids the warranty.
Bay Res. Vs. Tube Res. for dual loop Amarthfea Water Cooling 7 February 24, 2011 02:31 PM
Tube sizes and differences homer98 Water Cooling 6 October 7, 2010 05:06 PM
HTPC...for a tube TV? Lpfan4ever HTPC Systems & Software 29 September 3, 2010 09:20 PM
[WTB] WC Gear Rad / pump / res / cpu water block anabioz Buy/Sell & Trade 8 December 17, 2009 03:33 PM
What tube is this? biff Water Cooling 4 February 1, 2008 10:30 AM
