<~----> shops for petra's gel stuff? - Hardware Canucks
Old March 4, 2011, 09:16 PM
Cyclonicks's Avatar
Default shops for petra's gel stuff?
hey guys! I'm looking to dampen the sound of my dual ddc 3.2 setup and I'm interested in petra's gel stuff but from their website it looks like I can't get some
I've searched the web for a while without success.. can you guys help? or maybe suggestions for an alternative?
I've been told that I should get something for heat dissipation, I've seen some aluminum mounting bracket for those pumps, does it make a good dampening?
here's my pumps
thanks guys
Old March 4, 2011, 09:22 PM
ZZLEE's Avatar
rupper sheat. like a snall peace of pond liner. ??
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old March 4, 2011, 09:24 PM
AmuseMe's Avatar
You could always go to Home Depot or a hardware store and buy some soft rubbery like silicone and caulk it into a greased up mold and let it set? That is just off the top of my head. Silicone is only like $4.99 a tube too.
DEAD CA$H
Old March 4, 2011, 09:28 PM
Cyclonicks's Avatar
would be sufficient?
kinda slim compared to petra's gel stuff or say, the shoggy sandwich lol
it's for my second loop, first time around I had an xspc dual bay reservoir, so I'm lacking experience/knowledge with pumps directly on the floor of the case for dampening
Old March 4, 2011, 09:35 PM
ZZLEE's Avatar
EK-DCP PUMP Mounting Bracket & Silencer Kit EK-DCP PUMP Mounting Bracket & Silencer Kit [EK-DCP MOUNT KIT] - $9.99 : DazMode, Canadian PC Water Cooling and Modding Store
might have to mod it a bit. :)
Old March 4, 2011, 09:39 PM
Supergrover's Avatar
For my 655/BP watertank z ultra pump/rez combo I used a UN 3G bracket that was mounted to the side of my case and still had a slight vibration. It really wasn't that bad but I wanted complete silence adding a 1/8 inch piece of cork behind the mount and not torquing the mount fully, it was tight just not ubertight, deadened the vibration to nil.
As for Petras gel IDK where outside of Petra to buy it.
R.I.P.
Old March 10, 2011, 09:25 PM
I'm using this,
i dont know where you are from but in vancouver well richmond in bc, there store called daiso; japanese dollar store and i got these for 2 bucks
sweet deals at Petra's tech shop RONEDOGG New Builds 0 December 15, 2009 01:03 PM
PC shops in edmonton? Realityshift Off Topic 5 April 22, 2009 05:35 PM
Petra's gel stuff ... any good ? Ubermunkey Water Cooling 13 December 8, 2008 01:46 PM
Petra has SAN ACES IN STOCK! cyberspyder Air Cooling 10 August 10, 2008 11:52 AM
Petra's Order miggs78 Water Cooling 4 August 6, 2008 08:07 PM
