Old March 4, 2011, 12:57 PM
CTA's Avatar
CTA CTA is offline
i used exactly same... and it was no problem for me to install and uninstall..
just use tube as your force power... twist motion (flex the tube) to inside the barb... but remove tube is little difficult... just squeeze the tube as hard as you can then move to far left and far right... (make sure barb is install on the waterblock)
Old March 4, 2011, 03:33 PM
Dazmode's Avatar
Originally Posted by Hacksaw907 View Post
Primoflex LRT White 1/2ID w/ Bitspower Dark Nickel High flows 1/2IN barbs.
I dunno, maybe I'm doing something wrong? Because it most definitely did not 'slip on like butter.' Wish it did tho I'll try the water trick when I get home.
My be you have got smaller tube by mistake?
Orange Build: Final Video
HTPC Build: Final Video
Old March 4, 2011, 05:17 PM
Amarthfea's Avatar
I remember i got wrong tubing by mistake, took me forever to figure out it was 3/8" and not 1/2" lol.
I ended up gnawing on the ends to soften up the tubing so I could get it over the barbs.
~Elysium, I behold your beauty...
Old March 4, 2011, 05:43 PM
Keywork's Avatar
I put my loop together right before Christmas with primochill LRT tubing and BP barbs, both 1/2" like you have. Like mentioned above, dunking the end of the tubing in boiling/hot water for a few seconds allowed me to slip the tubing over the barbs with great ease.
Old March 4, 2011, 06:47 PM
lowfat's Avatar
Boiling water (not just hot) works amazing w/ Primoflex LRT. I could use 3/8ID 5/8OD tubing on 5/8" fittings (Eheim pump) after soaking the tubing in water I just took off the stove.
Mael
Big Lian Li
Forever Alone
Old March 4, 2011, 10:20 PM
AmuseMe's Avatar
+1.
Water needs to be hot! 5/8" you say? How about using the heat-gun? Anyone do this?
Old March 4, 2011, 10:46 PM
lowfat's Avatar
Originally Posted by AmuseMe View Post
+1.
I remember using a heat gun way back when w/ the old school Primoflex silicon tubing. Haven't tried it w/ PVC stuff though.
Mael
Big Lian Li
Forever Alone
Old March 5, 2011, 10:01 AM
Well, thanks to all of you, I've finally finished my loop without further damage to my hands The twisting trick to remove tubing and the little bit of water inside the tube before installing it really helped! Thanks again!
m11x vs (insert laptop here) THS Mobile Computing 3 September 10, 2010 12:42 AM
Safely Remove Hardware Can Remove EVERYTHING geokilla O/S's, Drivers & General Software 29 August 4, 2010 11:25 AM
[WTT] Trade my evga classified for your (insert mobo here)? quikgp Buy/Sell & Trade 12 January 30, 2010 01:20 PM
Tubing, tubing... what to choose? Dazmode Water Cooling 16 June 23, 2009 02:32 PM
[WTB] D-Tek Fuzion V2 Quad insert Lima Buy/Sell & Trade 3 June 1, 2009 11:19 PM
