Old March 1, 2011, 09:23 AM
JayDeeHobbit's Avatar
Default Feser 45 degree rotary barb - how are they for leaking?
I would like to pick up a few of these for my loop but I've gotten it into my head that I've read something about these being prone to leaking.
Anyone have experience with them that can comment?
"Try looking into that place where you dare not look!
You'll find me there, staring out at you!" - Frank Herbert
Old March 1, 2011, 11:06 AM
Prolab's Avatar
They probably didnt tighten the fitting very well.
I have 45 rotaries (at least 4) on my rig and no leaks (knock on wood).
Gaming Rig:
-Swiffy 655 & 360 rad, 360 XSPC Rad, HK Supreme HF, EK D5 top rev.2, AMD BE 1100T OC to 4.07 ghz, 16 GB G.SKIL F3-12800CL9Q-16GBXL, Asus Crosshair V, (2) XFX 6950 w/ XPSC WB, Crucial M4 128GB & 120 GB Vertex 2 EXT, (4) 2 TB WD Green Drive, Corsair AX1200, Win 7 Pro 64-bit
Server Rig
-AMD Athlon II 245 stock, Asus Mobo, 2 GB DDR2 Kingston, WHS, 500 GB WD Black, (2) 2 TB WD Green, (2) 2 TB Seagate HD, (1) Samsung 2 TB F4, Fractal Design R3, Antec 650 watt PS
Last edited by Prolab; March 1, 2011 at 12:33 PM. Reason: didnt realize you said rotaries
Old March 1, 2011, 12:22 PM
matsta31's Avatar
I have used the Feser and the bittspower double rotary. If you do take care to tighten correctly and you wont have any problems.
Sold hardware again.....
Currently using WHS hardware....
Old March 1, 2011, 12:43 PM
Excellent! I'll pick some up for my loop.
Thank you gentelmen :)
Old March 1, 2011, 01:44 PM
lowfat's Avatar
Don't put too much stress on the rotary and you should be fine. I've had a few of mine leak but just leasoning the tension and wiggling the rotary usually resolves it.
Old March 1, 2011, 02:41 PM
AmuseMe's Avatar
Like the others have said, it usually has to do with how much pressure/ tension is on them. Sometimes, rarely though, you will find one with a gimped inner o-ring, and will need to exchange it, but I don't think it happens often.
DEAD CA$H
Old March 1, 2011, 03:00 PM
Once again = Thank you gentlemen :)
Ya the when you tighten the barb (too much... too little) is always the delicate part of an H20 build IMO and you get a "feel" for it with experience.
Good to know it isn't a design/engineering or QC flaw though.
Old March 8, 2011, 08:37 PM
ForTheGG's Avatar
Just put my 45 rotaries on today, mine are bitspower though, but since I'm typing this message, they're not leaking ;)
"Sang Noir"
-Cooler Master Storm Sniper Black Mesh Edition
-Intel Core i7 920 D0 @ 4.116GHz 1.318VCore 24/7 HT On
-Corsair H-50 + 2x Cooler Master R4
-Asus RoG Rampage III Extreme
-6GB OCZ Platinum Triple Channel DDR3-1600 [7-7-7-20]
-2x EVGA GTX 295+ Quad SLI
-Corsair HX-1000
-WD 160GB Raptor 10000RPM
-WD 1000GB Black 7200RPM
http://valid.canardpc.com/cache/banner/1249140.png
Old November 29, 2012, 06:44 PM
Trial Member
Default Mine leaked
Old thread, I know, but just wanted to put in my 2 cents in, since the thread is still open.
I bought two feser 45 rotaries (the same ones as in the picture). Half a year later, one of them started leaking from the smaller fitting. It was screwed on tightly, but I could jiggle it in it's place.
It started leaking pretty badly a few months ago so I super-glued around the fitting as my solution.
The other one hasn't leaked at all.
TFC 45degree rotary compression fitting leaking.. elton5354 Water Cooling 4 December 22, 2010 10:55 PM
[WTT] Bitspower G 1/4" Black Sparkle Rotary 90 Degree IG 1/4" Adapter kyle_L Buy/Sell & Trade 0 March 14, 2010 07:03 PM
leaking capacitors - repair in GTA? pomatomus Troubleshooting 5 February 23, 2009 04:56 AM
MCR320 started leaking LooseCannon Water Cooling 10 February 20, 2009 03:14 PM
[WTB] 8800GT 512mb + EK full cover block + 90 degree barb jporter91 Buy/Sell & Trade 0 December 13, 2008 05:30 PM
