  #21 (permalink)
Old February 27, 2011, 11:54 AM
CTA's Avatar
CTA CTA is offline
okay i think its good to go...
thank you everyone for your helping...
  #22 (permalink)
Old February 27, 2011, 10:31 PM
AmuseMe's Avatar
Teflon tape is not needed, and it can, and will (eventually), find its way onto your loop. I use 3/8 x 5/8 tubing on half inch barbs. Only use my hands and pure masculine man muscles to screw the barbs on - except for the ones on my sLight, those I used a little bit of extra wrench torque with.
  #23 (permalink)
Old February 28, 2011, 05:21 AM
KaptCrunch's Avatar
once 0-ring is contacted no more than 1/2 turn or less of fittlng is my rule of thumb, not pulling the bejezous on wrench but some resistance
  #24 (permalink)
Old February 28, 2011, 12:19 PM
CTA's Avatar
CTA CTA is offline
this should be sticky or something... i mean there some good information before to do watercooling at first time...
Gamergrub Contest Leak ziikutv Rumor Mill 1 December 4, 2009 08:32 PM
i got a LEAK! kyle_L Water Cooling 9 May 1, 2009 05:10 AM
Question about Danger Den radiator barb fittings AERo Water Cooling 16 March 31, 2009 11:23 AM
Barb Question Supergrover Water Cooling 4 October 21, 2008 05:37 AM
Leak in T-line Phobia Water Cooling 17 June 9, 2008 04:37 PM
